IDLER oil
IDLER oil
callan
Send a private message to callan
hi guys,
what oil would you recommend putting in the front idlers of my D4.
have just rebuilt both idlers with new bellows and wear plates.
thanks.
Wed, Nov 14, 2012 11:44 AM
At the bare minimum you can use "Corn Head" grease from your Farm Supplier. It is a semi viscous sticky grease used on Combines.
If you use the SEARCH function here on this subject, you will find several recommendations of Brands and availability of "Track Lube".
Wed, Nov 14, 2012 6:31 PM
