Identifying D7 pony engines
Showing 1 to 10 of 11 results
TOP
Send a private message to TOP
I am pretty sure the pony engine on my 17A is not original as the starting crank is located on the side down low next to the track and the bracket for the vertical starting crank was torched off. For the purpose of repairing it and getting parts it would be nice to know what it was from. Any help would be appreciated.
Tue, Jul 30, 2024 5:25 AM
CRS93082
Send a private message to CRS93082
Sounds like the pony for a 7M or 3T.
Tue, Jul 30, 2024 6:36 AM
gemdozer
Thank you received: 8
Reply to CRS93082:
The 17a low serie had the hand crank mechanic horisontal with the magneto vertical
Tue, Jul 30, 2024 8:26 AM
TOP
Reply to gemdozer:
Still the bracket for the vertical crank was torched off.
Tue, Jul 30, 2024 9:18 AM
TOP
Reply to CRS93082:
Any way to positive ID it?
Tue, Jul 30, 2024 9:20 AM
gauntjoh
Librarian
Reply to TOP:
Pictures would help.
Tue, Jul 30, 2024 1:12 PM
TOP
Here are some pictures. Pardon the hoses. I am removing a homebuilt auxilliary hydraulic system that I think was meant to run a tilt cylinder on the dozer.
Tue, Jul 30, 2024 9:52 PM
gauntjoh
Librarian
Reply to TOP:
That does not look like a starting engine from an earlier tractor like a 7M. Probably a later model.
Tue, Jul 30, 2024 11:03 PM
TOP
Reply to gauntjoh:
One difference from what the parts/service book says is the way the governor linkage is set up. This one has a rod that snaps onto a ball on a short arm below the pivot while the idle spring is on a long arm above the pivot. The arrangement I expected was that the governor linkage and the idle spring would both be on the same side (above) the pivot.
I wonder which D6, D7 and D8 pony motors will swap with this machine?
Wed, Jul 31, 2024 1:21 AM
gemdozer
Reply to TOP:
The d8 14a use the same model and the rod picture from yesterday is connect to the carburator lever and the other end is connect to the top governor lever
Wed, Jul 31, 2024 3:26 AM
D8Dude
It appears to be the correct starting engine to me, here's a picture of the starting engine on my 17A [attachment=77245]IMG_20230405_173128014.jpg[/attachment]
It has the upright crank, but it's removed at the moment for exhaust pipe repair for the starting engine.
Wed, Jul 31, 2024 4:14 AM
| Hartley - South Australia
Newby Hall Tractor Fest
