I want your opinion
I want your opinion
Showing 1 to 10 of 32 results
deckert d69u
Send a private message to deckert d69u
I have drug home a D2 5u15175 it has been sitting for quite some time 8 years more or less At this point the only thing I am sure that still turns is the pony motor. I think the clutch is froze on main motor. The left steering clutch also doesn't seam to work Tracks slide also I'm thinking the brakes are locked up
Oil looks good no water Antifreeze is still in radiator transmission had very little oil in it. I filled it with d diesel fuel from the fuel tank.
It also has a loader on it to complicate getting at it to work on it.
SOOOOO is it worth trying to save ?? Or do I scrap it and spend my $$ on something that's already running ?
[attachment=26433]image.jpg[/attachment][attachment=26434]image.jpg[/attachment][attachment=26435]image.jpg[/attachment][attachment=26436]image.jpg[/attachment]
Les
d6 9u dozer
Russel hiway patrol no 1
Wabco 555 grader
superA farmall F 12,F 20 and various pcs. of rusty red tractors
Fri, Dec 12, 2014 1:04 PM
Thank you received: 140
Hi, Deckert d69u.
A'course, dollars-n-time come into it but me thinks you would have an item of some interest there if you did decide to save it. I yain't ever seen one like it afore. 'Course, that's not to say they yain't around, just that I yain't SEEN any like it afore.
Maybe do some further investigation without spending a whole lot to get a clearer idea of just what is involved before making the hard choice?
Fri, Dec 12, 2014 1:15 PM
7upuller
Hi, Deckert d69u.
Hey Deckert,
My question is, do you enjoy the challenge of tearing into something rebuilding or fixing it. Some people enjoy taking things apart no matter how broken it is to bring it back to life. Some people don't have the time to repair, they just want to own, show, and operate one. So my question to you is which type of person are you? Even if your the guy who wants to own, show, and run it, your gonna get your hands dirty. Roflmao....No matter which way you want to go, there are lots of tractors to choose from. glen
Fri, Dec 12, 2014 1:58 PM
Steve A
Reply to 7upuller:
Hey Deckert,
I would have to put some effort into it, it would be to hard to just walk away.
Fri, Dec 12, 2014 6:33 PM
OzDozer
Reply to Steve A:
Sit down with a piece of paper and write up the list of repairs needed. Then add to the list just how many hours it will take to fix all those things, and how much time you have to spare to put those hours in.
You might get a shock when you add it all up and reach the bottom line.
To my mind, that poor ole D2 has done more than what one could ever reasonably expect of a D2. It's had a honkin' great loader mounted to the machine that I'm surprised, hasn't broken the tractor in half.
It has cast street pads that are only good for concrete floors in factories or in steel mills. It has seized brakes and clutch, a tranny that has been effectively run out of oil, you're not even sure if the main engine even turns over.
It looks to me like a badly abused and neglected money pit. You will find a lot more wrong than you can initially see, and what you already know about.
If you like wrenching, pulling components apart and re-assembling them, spending money constantly on spares, and spending heaps of time sourcing parts, then this is the tractor for you.
You will also have to keep in mind it could be 3-4 years before it's a runner, if you can only spare occasional hours on it - which is what the scenario is, for most people who already have a full-time job.
If you want a tractor fully operational real soon without pouring a lot of time and money into it, you're better advised to find a tractor in much better condition that has been properly cared for.
Just my 0.02c worth for today, and it actually cost you nothing. 😄
Regards, Ron.
Fri, Dec 12, 2014 8:14 PM
Thank you received: 78
Reply to OzDozer:
Regards, Ron.
Hi Deckert, if you choose not to get it running, rather than scrap, see if you can dismantle it for parts - the folks on the forum would appreciate an extra supply - just a thought : )
Fri, Dec 12, 2014 8:40 PM
Texasbest
Send a private message to Texasbest
Deckert, I would be interested in the Street Pads if you decide to part it out.
You will be much better off and happier finding a runner that needs some TLC and has a decent undercarriage than getting into a major project like this. Trust Me...
I'm in the middle of a D2 Traxson project, have an 18/32 Crossmotor Case that needs to be put back together & painted. Need to add on to my shop, build another storage building, get the house rewired...
Roby Whitehead
Fri, Dec 12, 2014 9:24 PM
8C 361
Thank you received: 12
It looks like it has possibilities. Do not scrap it. Do not try to part it, no one will come and get anything.
Try to sell it to someone who wants to fix it. Maybe the engine can be unstuck and got to run. Maybe the steering clutch can be unstuck. The tracks look fairly good.
Fri, Dec 12, 2014 9:35 PM
STEPHEN
Reply to 8C 361:
If the pic was was outside with good light and a clean background, I guess it would look better. What does the tag read on the loader side? I see the weight, how about a non-oscillating track frame group? Could be tons of good parts here.
Fri, Dec 12, 2014 10:46 PM
Reply to STEPHEN:
That Cat is a "Dog".
Fri, Dec 12, 2014 11:18 PM
rturn3060
Send a private message to rturn3060
If you want to restore this machine go for it, but my experience owning modern cat track loaders they still self destruct, especially the under carriage. This D2 was designed as a farm tractor with an after market loader grafted on and you will find the gear train probably worn beyond repair without extensive requirement of new parts and machine work Notice the oil leak on the final drive which rarely leak until the bearings go out.
Sat, Dec 13, 2014 12:19 AM
