I know... Wrong Color- Oliver Cletrac
Showing 1 to 10 of 11 results
frochevy
Send a private message to frochevy
My dad retired last year and has been busy with many projects. Current one is an Oliver Cletrac he bought when I was about 10yrs old. (I remember running the winch for him in the winch truck to winch it on the trailer). It's had a very rough life. I wanted to share it's resurrection. He rebuilt the engine 20 years ago and it has been sitting so he had to tear apart again and clean up. Tractor had a seat made along with a rear weight box along with Cat handles welded on the steering brakes. This tractor had an add-on loader to it. If anyone knows where to get parts for these, please share. He's wanting to find an original seat,fenders, etc along with some other parts. Hope you enjoy...
Wed, Mar 29, 2017 12:16 AM
frochevy
I have a short video I tried to upload showing it running but it's not working. What format does it need to be in? And how large of a file can it be?
Wed, Mar 29, 2017 12:31 AM
BobPV15
Send a private message to BobPV15
Reply to frochevy:
That looks like an Oliver HG that later became the OC 3. Landis Zimmerman of Zimmerman Oliver Cletrac would be your best bet for parts. He is in Ephrata Pa 717 738 2573.
Wed, Mar 29, 2017 12:42 AM
This seems to be the major parts source. Actually seems to be a bit of a come back of those HG models.
Wed, Mar 29, 2017 12:43 AM
Even ebay has parts occasionally.
Wed, Mar 29, 2017 12:44 AM
frochevy
Thanks for the information and comments. Every step of this build has been running into some thing broken, cracked or patched up by previous owner. He has been doing a lot of fabrication along the way. Hopefully sometime I can share the story on the engine build. He ran into many problems with it along the way. I believe the loader is a name brand loader. He has books on the machine including the loader. He might eventually put the loader back on. He is trying to get this ready for a tractor show coming up in August in Winfield, KS. K&O Gas and Steam Engine show. I believe the theme this year is tracked machines. I plan to haul my 3J D2 down. Dad plans to have this Oliver going as well as take his HD-5 Allis (as well as 5 or 10 Allis wheel tractors).
Wed, Mar 29, 2017 7:02 PM
frochevy
Reply to frochevy:
Dad ordered an original seat from Zimmerman Oliver. Thanks for the tip. He got it painted up and installed.[attachment=41810]39953.jpg[/attachment][attachment=41811]39956.jpg[/attachment]
Fri, Apr 28, 2017 9:19 AM
frochevy
Reply to frochevy:
My dad has also refused to buy a "repop" grill. So he made use of a 55 gal drum lid and some time to fix his old grill that had been hacked on. He says it's not perfect but it'll work. I think he did pretty good if you realize the hand tools he used (hammer, chisel, dolly, etc... and oxy acetylene torch) I was really impressed and wanted to share.[attachment=41812]37792.jpg[/attachment][attachment=41813]37795.jpg[/attachment][attachment=41814]39999.jpg[/attachment][attachment=41815]39994.jpg[/attachment][attachment=41816]40003.jpg[/attachment]
Fri, Apr 28, 2017 9:28 AM
cojhl2
Reply to frochevy:
Very nice job on the grill:high5:
I used to load Cow Manure with one of these tractors. Very nice and handy loader tractor, a little bouncy but worked very well.
Fri, Apr 28, 2017 9:04 PM
ronm
Reply to cojhl2:
Your Dad had better go into the grille business...that's awesome.
Fri, Apr 28, 2017 9:06 PM
Pat in WI
Reply to frochevy:
frochevy,
Thanks for sharing your story and pictures!
Most of these smaller HC's and OC's that had a blade or loader, almost always cracked the frame on the left side. In your second picture at the top right, usually at the front or back of that U shaped cutout in the frame rail. That was the weakest spot in the structure.
Ware Company made the most common front end loader for the small Cletrac/Olivers.
They have good power to weight ratio's but hard work will reduce the tractors longevity. Not as heavily built as a Cat. Still are a great little crawler though. They worked great cleaning out stalls in barns and in other tight areas.
Pat
[attachment=41839]IMAG0250sm.jpg[/attachment][attachment=41840]IMAG0254sm.jpg[/attachment]
Pat in WI
Fri, Apr 28, 2017 9:11 PM
