I have some questions regarding my 1955 7u/ht4
Showing 1 to 10 of 20 results
55HT4
Send a private message to 55HT4
I have a 1955? Cat d4 7u/ht4 #31435, it was my fathers before mine, and his fathers before his. Anyways, I have a few questions. The right side steering brake pedal has tons of resistance when I press it, and does not get full travel, it seem like the brake shoes? are stuck, is there any way I can try to free these without having to do a teardown? Since this has the ht4 loader it has the surge? tank on top of the motor, how much hydraulic oil does that hold? and can I use iso 32 (10w) Hydro Oil? Where can I find a dipstick for the transmission oil, and any other ones? (other than engine) Thank you
Josh
Thu, Mar 28, 2019 1:50 AM
Remove the @ 6"x 5" covers on the back of the transmission case and take steel bar and a hammer and tap on the top of the brake band linkage and they should free up or pop loose from the brake drum. Then check the pedal travel.
Thu, Mar 28, 2019 1:56 AM
55HT4
Where is the linkage, i took off the cover on the back and i could not see a linkage, i even had a friend press the brake and i only saw the band move a little.
Thank you
Josh
Thu, Mar 28, 2019 3:43 AM
Reply to 55HT4:
Thank you
Josh
The linkage is up on top but you can tap on the band lining clamp or connector and free them up. If they are loose then the linkage may be froze up. Remove the cover under the seat to get to them.
Thu, Mar 28, 2019 4:09 AM
Reply to 55HT4:
Thank you
Josh
my 7U has a plate underneath the seat, remove it and you can see the linkages and adjustment for the bands in there
Thu, Mar 28, 2019 4:11 AM
55HT4
Reply to dpendzic:
Ok thank you guys. The seat has to be removed to access this cover right?
do any of you know how much hydro oil i need in my tank? I have the extra tank on top of the engine.
Thank you
Josh
Thu, Mar 28, 2019 4:30 AM
Reply to 55HT4:
Thank you
Josh
yes the seat has to be removed--can't remember if there was a tool box under the seat also--don't know the amount of hydraulic oil, but the iso 32 should be fine for Maine's cooler climate
Thu, Mar 28, 2019 4:59 AM
55HT4
Reply to dpendzic:
I found a plate under the seat that can be accessed without the seat being removed, is that the one? the plate seems to go to the wall of the fuel tank from the front.
Thank you
Josh
Thu, Mar 28, 2019 5:11 AM
Reply to 55HT4:
Thank you
Josh
Yes just remove seat cushion, not seat frame.
Thu, Mar 28, 2019 5:31 AM
55HT4
Ok thank you.
Josh
Thu, Mar 28, 2019 5:34 AM
Reply to 55HT4:
Ok thank you.
Josh
there is also another plate below the floorboard that gives access to the brake linkage and the lower area of the adjuster
[attachment=53224]left side rear.jpg[/attachment]
Thu, Mar 28, 2019 5:55 AM
| Kingaroy, Queensland
