I found this in my 17a oil
dan83
Send a private message to dan83
I just changed the oil in the 17a and found this metal its aluminum I think I'm hoping its old ive only put 100 hours on it and it works perfectly no weird sounds still has good oil pressure any ideas [attachment=37860]image.jpg[/attachment][attachment=37861]image.jpg[/attachment]
Sun, Sep 11, 2016 6:39 AM
Thank you received: 60
Not a good sign....usual suspect is bearing material.
Sun, Sep 11, 2016 6:59 AM
willitrun
Send a private message to willitrun
sadly that's what i found in my old 7m filters. turned out to be a connecting rod bearing. best check it out, might save the crankshaft.
Sun, Sep 11, 2016 9:29 AM
chuckb
Reply to willitrun:
that is not good news i think you can access bearings thru the side hopefully you caught this in time
Sun, Sep 11, 2016 10:36 PM
mrsmackpaul
Reply to chuckb:
Yes I would agree with everything that has been said above and yes its not good news, but there is some good news it isnt knocking yet so with any luck you have caught this time and as said hopefully the crank is still spot on and will be a fairly cheap fix
Paul
Mon, Sep 12, 2016 3:17 AM
