Hyster winch
Hyster winch
catd69u
Send a private message to catd69u
I was wondering if there is any parts source available for older Hyster winches. I have a model d6n, and I would like to renew the lining on the brake band. Thanks in advance for any comments....................
Barry Franklin
Sat, May 20, 2023 10:53 PM
Jimmy977
Send a private message to Jimmy977
Not really any new parts available for the old hyster units. The brake band can be relined. You can purchase lining materials online. But I would do an online search for brake and clutch relining services. Many places do this work. Otherwise for gears and shafts, that would be used parts, possibly from tractor salvage, dismantling companies. Bearings most likely available new. Other members have more experience with Bearings. But you just need the number off the Bearing, and do internet search for number, or call Bearing suppliers. If you plan to use your winch alot, keep your eye out for a complete winch as a backup parts unit.
Mon, May 22, 2023 7:22 AM
PNW.Hillbilly
Send a private message to PNW.Hillbilly
Reply to Jimmy977:
Really easy to find the bearings and seals. The exception to this might be the giant seal that goes around the drum, depending on the model. The shafts and gears you will need a parts winch or a machine shop.
Tue, May 23, 2023 11:02 AM
Thank you received: 52
Reply to PNW.Hillbilly:
the winch on our machine used felt as a seal on the drum. we bought some from the bearing joint we got the bearings from. note ours isnt a hyster winch
Tue, May 23, 2023 3:12 PM
catd69u
Reply to trainzkid88:
Thanks for all the replies. I do need to reline the brake band. Other than that the winch seems to work. I'll have to search for lining, and keep my eyes open for another winch for parts. Thanks again fellows.........
Barry Franklin
Wed, May 24, 2023 7:38 PM
