Hyster Logging Arch
Hyster Logging Arch
Showing 1 to 10 of 31 results
Arthropod
Send a private message to Arthropod
Look what I found. Old Hyster logging arch. I suspect from the late 20's, early 30's. The patent tag says 'Canada Petented 1931'. Should work nice behind my D2 or RD4 (if I ever get that thing running).
Welded some angle onto my trailer deck because the arch is wider than the deck (arch is 8' wide). The angles worked as a good cradle. Winched it up no trouble. Made it the two hour drive home with no mishaps. I was worried about tongue weight, but the trailer tracked good.
Sat, Oct 31, 2009 12:58 AM
Arthropod
A few more pictures.
Sat, Oct 31, 2009 1:02 AM
Reply to Arthropod:
Doesn't look all bent up and abused either!
Sat, Oct 31, 2009 2:31 AM
Dunefanatic
Send a private message to Dunefanatic
Reply to Arthropod:
Arthropod,
That arch looks really clean but I think it is a Hyster D4 size arch, not a D2 arch. I have a Hyster D2 arch that came from Ohio coincidently and it is parked next to my Hyster D4 arch from Orego and they are close in size but the main difference is the support from the wheels tieing in near the lower roller.
Greg
Sat, Oct 31, 2009 2:35 AM
side-seat
Thank you received: 15
Reply to Dunefanatic:
Arthropod,
Greg
what happened to your buddy's hand? I hope it wasn't from loading.
Sat, Oct 31, 2009 3:35 AM
hicrop10
Reply to side-seat:
I will look in my literature for a spec sheet on it.If you would like a copy of it send me your mailing address and I will send it to you.Mike
Sat, Oct 31, 2009 4:39 AM
Arthropod
Reply to hicrop10:
Mike, that would be appreciated. I will send you a message.
The fellow with the hurt hand was the seller. This is bad...he reached under a mower deck while the blades were turning. He said he just thought it was fully disengaged and his hearing is so bad he didn't hear the blades turning. All his fingers on that hand got chewed pretty bad. One finger was cut off at the outer joint. Two fingers might not work. I felt really bad for him.
I figured the arch is more of a D4 size, but one of my D2's is a 1955 model, which is more like the size of my RD4 anyway. And the arch was in such fine shape. I was told that the original owner (now deceased) pulled the arch with an International farm tractor.
I had to try it out, so I hooked it up as soon as I got it winched off the trailer. The real grainy picture is a screen capture of a video my wife took with the camera. I posted the video on U-tube. The right hand steering clutch on my machine is stuck, so right turns are a backup operation. I'll post the link if the video shows ok.
Sat, Oct 31, 2009 7:01 AM
B4D2
Reply to Arthropod:
What a great find. I wish I could find one like that. I could reallyu put it to work too. It looks as if you won't have trouble finding work for it either. Congrats!
Sat, Oct 31, 2009 7:27 AM
Arthropod
Reply to B4D2:
Thanks! I put my first video on YouTube. Really grainy because it was taken with a digital camera. And my D2 has a stuck right clutch and the winch brake is slipping, so I am fumbling a bit. But heck, it is a D2 doing something, so it can't be all bad. And my wife didn't care that I took a log across the driveway. It's been a long day. I've been up since 4am. Had to get my winch rigged on the trailer before heading out to get the find.
http://www.youtube.com/watch?v=Qwf_kAC6TbU
Sat, Oct 31, 2009 8:08 AM
catsilver
Reply to Arthropod:
Hi Anthropod,
Its great to see the D2 make easy work of the logging arch, nice to hear on Youtube as well. Do you realise that if you had the winch 'underwound' instead of 'overwound' you would get more line pull, it would be slower and more controllable and the brake would be more effective, the end would be a little further from your neck if you broke the cable as well.
Many used them overwound to give a bit of lift when pulling timber directly but underwound gives more pull.
I'm just jealous it's not in my backyard!
Sat, Oct 31, 2009 4:09 PM
Arthropod
Reply to catsilver:
Hi Anthropod,
catsilver, No, I wasn't aware it best to under-wind the cable, thanks. I'm basically a novice when it comes to actually the best way to use the older equipment, though I am always trying to better my knowledge. Before getting into electronics for a career I worked for some excavating companies running a Case backhoe, CAT 225 trac-hoe and a track loader. This was back in the late 70's, early 80's. But now I just tinker with really old stuff as a hobby. I was going to look through my 'Moving the Earth' book to see what information I could find there regarding an arch. I may change the cable winding on the winch, but I have three D2's with winches and not sure which one I will end up using with the arch. I am thinking one of the others without a blade.
I was driving a different D2 around a show this past summer and this really nice fellow flags me down and says he has just the thing I need sitting at the edge of the woods. It was this arch. We exchanged numbers and after a short time, one failed trip to pick it up, it's in my yard. My first attempt to get the arch failed because he wasn't sure it's measurements, but he felt it would fit on my trailer. It did not. So I went back home, modified my trailer and made another attempt. I was on vacation this week, so no big deal.
Thanks again for the recommendation.
Sat, Oct 31, 2009 6:21 PM
