Reply to Hillbillybjopkr:
I'm actually looking for just the control handle....I know my winch turns...just did it one day.......but I'm sure needs a rebuild....stil looking myself
I just want to give this a bump and update it a little. I'm still looking for a winch. I have found a D4 hyster or two out there but none with controls and the controls for these winches are different. My Father has a D4 winch on his tractor and I guess I plan to stick with my N series at this point. Also I have found the gears I need will not interchange between the two winches, the N series uses a 32 tooth sliding gear while the D4 series uses a 28 tooth, both have different part numbers as do the intermediate shafts used in each series. I have further found that the intermediate shaft, which has two gears integral to it, so one can't just replace one gear, you need the entire shaft.
All this probably means finding another winch for parts. I'm hoping someone has one kicking around with no controls that they would part with. If anyone knows of one, I'd love to hear about it.
Thanks,
Joe
