Hyster D2N Project
Hyster D2N Project
Showing 1 to 10 of 48 results
Cysco
Well my intention was to clean the outside, paint and install the D2n winch but for some reason I can't resist taking things apart and going through them. Is it a good thing.....who knows but I must like it because I keep doing it..... 😊
Anyhow I'll post a few pictures along and maybe it will help someone else. Any help or comments are greatly appreciated as I am no expert but do try hard to do things properly.... 😊
Have a good day......Bill
Mon, Mar 27, 2017 8:44 PM
Cysco
Here are a few more pictures.................
Mon, Mar 27, 2017 8:47 PM
Arthropod
Send a private message to Arthropod
Reply to Cysco:
Yours is in very good internal condition. Some years ago I took two D2N winches and made one. Had them both totally apart as you have. Not rocket science. Very well built and easy to work on. I like equipment like that. One of the two had been worked so hard that the input shaft was twisted and one gear was broken internally.
All of the bearings are pretty much standard stuff you can buy aftermarket. Just cross the number on the bearing case. I replaced the input shaft bearing with new when I did mine. I think one other bearing went back new, but most I reused since I just picked the best of the two old bearings. My winches don't see tons of use so they will outlast me easily.
A negative with these winches I feel is there is no disconnect clutch from the main transmission. You can choke out the diesel if pulling hard enough. Been there, done that. And I find it very hard to wind the cable back in neatly. I usually hook to a tree and drag the machine back, touching each brake to try to reel the cable nice, but it is very hard to see the cable reel when seated. You have to lean way back over, then it is hard to work all the controls. It is nice having the winch. I've pulled a friends F250 king cab diesel out of some muddy soup. Pulled over some trees and once got my backhoe so stuck I didn't think it was ever coming out. Chained the D2 to a tree and a friend pulled the backhoe while I worked the buckets and it finally came out.
Mon, Mar 27, 2017 9:02 PM
WyoCat
Reply to Arthropod:
Looking good Cysco!!
Chad Enyeart
Mon, Mar 27, 2017 10:30 PM
Reply to WyoCat:
I have a D8N winch apart, it needs all new bearings, ya cha ching! will sell for parts. Its a two speed winch. Anyone have a good working used one?
Mon, Mar 27, 2017 11:26 PM
Thank you received: 78
Well, it's good for the winch! : ) so that's a mark in the credit column
Tue, Mar 28, 2017 12:45 AM
Cysco
Just a couple more pictures............
Yes...the winch is in really good shape.....all gears show minimal wear......the rust is what is making it tough especially on the bearings. I found them all fairly cheap and USA made so I am going to just replace. I found all the seals and need to match up the one o-ring . The gaskets will have to be made as well. I called Allied to see what they had and found out they have nothing but an online site to get the manual.
I'll post more as I get farther along.
Have a good evening.....Bill
Tue, Mar 28, 2017 5:57 AM
Bruce P
Thank you received: 40
Reply to Cysco:
Looks great, thanks for taking the time to post.
Bruce P.
Tue, Mar 28, 2017 7:19 AM
Reply to Bruce P:
Bruce P.
Bill, would you be able to post that list of replacement part #s you purchased as anything that's in common with the D2 winch (non-N) I'll want when I get to do mine.
Tue, Mar 28, 2017 7:23 AM
chriscokid
whats the pile of needles from, was there a bad bearing, or did it come apart during removal?
Tue, Mar 28, 2017 7:29 AM
mog5858
looking good never seen inside one of them before. thanks for taking the time to show us around lol . keep up the good work.
Tue, Mar 28, 2017 7:34 AM
