Hydreco pump parts Ateco ripper
ld8h
Send a private message to ld8h
I have my Ateco ripper pump off of my 1960 or so D8H and have determined it is a Hydreco 3000 series. I need to find a parts source one seal in particular that keeps the hydraulic oil from running into the transmission. I called Hydreco and gave them the casting number and they told me it is a 3000 series and that they are obsolete and there are no parts for them. Anyone know of a parts source for these? I can probably fake the oring and the feed pipe seal. the one I realy need is the first in the one pictured left on the seals picture.
Thanks Loren
D8H 46A5893, D3c, Kubota Kh-191, Bobcat 963G, Old White Dump truck. 1967 Lincoln welder.
Diesel Generators
Thu, Sep 18, 2008 11:08 AM
bigequip
Send a private message to bigequip
Try O'Rings n Things in Fontana. They are across the street from the entrance to the Speedway, down the street on the left. They have all kinds of seals and orings. Everyone goes there for parts.
Here is their address:
O-Rings & Things
(909) 357-7110
14546 Hawthorne Ave, Fontana, CA
My 2 cents.
Thu, Sep 18, 2008 11:19 AM
Are there any numbers on that seal?
Thu, Sep 18, 2008 11:21 AM
ld8h
Fontana is a ways away and usualy quite a bit of trafic.
I didnt think to look for a numbers on the seals I will do that tomorrow.
Diesel Generators
Thu, Sep 18, 2008 1:43 PM
Old 3T lover
Reply to ld8h:
If everything else fails....you might try this.
TEREX/EUCLID used gear type and vane type pumps in their buldozers. If it had a vane type pump, they used one or the other of a Hydreco or a Vickers. They looked just alike and some parts would interchange even, like the main seal and shaft in the pump. You "MIGHT" be able to find a Vickers seal for that Hydreco pump.
Thu, Sep 18, 2008 9:10 PM
carlsharp
Send a private message to carlsharp
Reply to Old 3T lover:
Hey Loren, look thru this site, they seem to have a lot to choose from-
http://www.usseal.com/mechseals.htm
CS
Carl Sharp
Chino, CA
2xPV15; 22 2F; D4 5T
Various other oddball stuff
Vids: http://www.youtube.com/profile?user=carl4043
Fri, Sep 19, 2008 12:27 PM
