Hydraulics question
Hydraulics question
BrianK
Send a private message to BrianK
I'm trying to determine if the cylinders can be fixed for a reasonable price. The cylinders are leaking quite a bit on either side. I'm assuming that it's probably a seal that needs replaced. It looks like it has some kind of secondary seal before the actual cylinder. Is this something that's easily serviced? I don't have a 'hydraulics 101' book yet. I haven't messed with hydraulics before, something new to me.
Is there a book out there that would cover these? Any idea on the age?
Thanks,
Brian
Thu, Feb 21, 2008 9:00 AM
OldNuc
Send a private message to OldNuc
The picture is sufficiently fuzzy and dark that I am not sure but that might be a packing follower and those cylinders use a string type of packing. IF SO then it is merely a matter of backing off the nuts and pulling out the follower and then adding a ring or two of packing.
Those are low pressure cylinders and they look old enough to be of that type.
Thu, Feb 21, 2008 9:26 AM
dead axle
Send a private message to dead axle
Reply to OldNuc:
If that has a bolt on rod gland cap you can remove the bolts slide the cap down and dig the old packing out with a screwdriver. Purchase some chevron style packing from an equipment dealer cut the individual pieces diagonally and slip them over the rod and shove them up in the cylinder head. Make sure and stagger the cuts just like putting piston rings on a piston. This is a quick field fix but will last quite awhile. Good luck!
Thu, Feb 21, 2008 9:42 AM
carlsharp
Send a private message to carlsharp
Reply to dead axle:
But FIRST, just tighten the nuts a bit and see if it helps!
CS
Carl Sharp
Chino, CA
2xPV15; 22 2F; D4 5T
Various other oddball stuff
Vids: http://www.youtube.com/profile?user=carl4043
Thu, Feb 21, 2008 12:29 PM
steve n carol
Send a private message to steve n carol
Reply to carlsharp:
CS
[quote="carlsharp"]But FIRST, just tighten the nuts a bit and see if it helps!
CS[/quote] AAAAHHHH, After reading this, I think we might be related!!!😄
Thu, Feb 21, 2008 10:19 PM
