Reply to W. SMITH:
Ray, Remember that a rear PTO run hydraulic pump quits running when you disengauge the clutch . A PTO pump run off the front of the engine will give you live hydraulics all of the time. I am not sure if the front mounted PTO pump will fit on the early 3J series D2's. W. SMITH
Which part of the US are you in? Hydraulic parts leak all over no matter how clean the seller thinks they are. They are heavy which adds to the cost of shipping. All the iron parts that will be needed will add to the cost of shipping and labor, plus getting a good blade to put on it. Getting a good setup that will take the abuse of a D2 can be tricky! I have a blade on mine and to look at it makes you wonder how much use and abuse its had! A 3J will be weak in the main spring, have smaller idlers and less rollers making for a little bucking bronco. At dirt moving demonstrations, I am forever bombarded by gentlemen that ask, "How do you move dirt so well?" As they have D2 and can't seem to level dirt with it. I explain about the larger idlers, heavier main spring and rollers being incorporated into the build of the machine, not to mention the different gear ratios in the transmission. CAT's setup for Ag have different gear ratios than CAT's setup for construction work. There are a couple of guys advertising parts and pieces in Nevada and California, there may have been an advert recently for a guy selling parts in Illinois but right off the top of my head I can't think of one on the East Coast. You can put the pump on the back, my Laplante-Choate is on the back. When you stop at the end of the push, pull the lever back to raise the blade, change gears, back up, the blade will rise. The only time you'll wish it was live is when you are trying to finish the grade at which point you want the blade coming up before you start moving. There are alot of threads in here on front mounted pump conversions, belt driven pumps and rear mounted pumps. Search around, you'll find lots of info. My advice is, if its a nice AG CAT, then leave it unless you can buy it really cheap to make a conversion worth while, better would be to find a better machine suited for want you want to do.
Jeff
