Hydraulic update maybe?
cat_d7_17a
Send a private message to cat_d7_17a
I seen this on craigslist and wondered if I could fit this to a 17a to add tilt. Run the pump off the crankshaft still? http://kansascity.craigslist.org/hvo/4372195680.html
Thu, Apr 3, 2014 11:00 AM
mrsmackpaul
Seen what I see nothing maybe lost on the way here
Paul
Thu, Apr 3, 2014 4:01 PM
cat_d7_17a
Reply to mrsmackpaul:
Paul
Sorry for some reason it didn't go though the first time
Fri, Apr 4, 2014 12:54 AM
Reply to cat_d7_17a:
The #183 Hydraulic Control (72H1-up) is a 70 gpm two section pump and control system for the 36A4469-up and 46A10725-up D8's. The pump is meant to be driven off the rear engine power take off at 1240 rpm and 1000 psi with relief valve set at 2250psi.
The 17A full load crankshaft rpm is 1200 which would be a close enough match for rpm if you can arrange a drive. Mounting and plumbing would be a bit of a challenge.
Further check of the 17A with #172/173 (67G1-up) Hydraulic control shows same two section pump, pump body and shaft, 54 gpm main and 17 gpm second section. So it appears the 72H1-up pump could be driven from the 17A power take off.
The #172/173 HC does use a different tank and valve arrangement though so fitting the 183 tank could still be a challenge.
Fri, Apr 4, 2014 4:37 AM
dick
Send a private message to dick
A much cheaper solution would be to use a larger power steering type pump and reservoir assembly. There is usually plenty of room to mount this to the side of the block where you can drive it off an additional fan pulley. I have done this on 3T and D7E cats. You only need enough oil capacity for differential caused by the cylinder rods travel. You may use either a manual or solenoid control valve.
Fri, Apr 4, 2014 8:55 PM
