Hydraulic unit
Hydraulic unit
kracked1
Helping a friend with a hydraulic leak. Need to know which hydraulic unit his D6C 10K1728 would have. It is a 3 valve, Blade with tilt and a ripper. Need to change out the orings where the lines hook to the valves/tank. Cant find a tag on the unit anywhere.
Wed, Mar 2, 2022 9:25 PM
D6C 10K1728 - Three Valve Hydraulic Control for 10K1-6983 is a s/n 44G1-44G112, arrangement# 8S460.
Thu, Mar 3, 2022 12:42 AM
kracked1
Thank You much OM
Thu, Mar 3, 2022 12:49 AM
Reply to kracked1:
Thank You much OM
I left out the "163" designation but you probably knew that.
Thu, Mar 3, 2022 12:57 AM
kracked1
Thanks much.
Thu, Mar 3, 2022 2:52 AM
