Hydraulic pump input shaft seal
6-9Uskinner
Send a private message to 6-9Uskinner
I have a D6-9U with a bad seal at the input shaft on the hydraulic pump. Does anyone know if it can be replaced without removing the radiator and hydraulic tank?
Tue, Oct 15, 2024 8:56 PM
Online
Thank you received: 59
There are several arrangements of Cat hydraulics, so I may not have seen them all. None I have seen would require the radiator he removed. But all would need the tank to come off the tractor, to get to the pump.
Wed, Oct 16, 2024 11:34 PM
