Hydraulic Info.
Hydraulic Info.
straycat.inc
Send a private message to straycat.inc
I need help on things, first, I'm looking to buy a parts book and service book for the hydr. system on my D7 3T 27820. Hydr. Model 46 s/n 46C 1863.
Second, I'm looking at a D8 14A 8667 with a hydr. angle blade. Would like to know the year of this machine, and if the hydr. system is the same as my 3T. There is no info. tag, but looks similar. If it is different, what would the model no. be?,
Thanks Richard
Mon, Mar 16, 2015 3:40 AM
The D8 14A uses the #48C1-up s/n hydraulic system
The 3T s/n 23647 uses the #46C1-up s/n hydraulic system
Both use 100gpm pumps at that s/n but they are a different pump part number.
They are both very similar systems.
Your 14A8667 is a 1958 model.
Mon, Mar 16, 2015 9:42 AM
straycat.inc
Thanks Old Magnet
Richard
Mon, Mar 16, 2015 1:58 PM
tctractors
Reply to straycat.inc:
Thanks Old Magnet
Richard
100gpm??? is this correct.
tctractors
Tue, Mar 17, 2015 3:00 AM
straycat.inc
Reply to tctractors:
tctractors
yes it is.
Tue, Mar 17, 2015 4:15 AM
catsilver
yes it is.
They might be 100gpm pumps although 100lpm seems more likely (100gpm at 150psi is around 98hp) but this rating is at around double the speed they actually run at on a D7 or D8.
Tue, Mar 17, 2015 4:45 AM
