Hydraulic cylinder rod rust prevention
Showing 1 to 6 of 6 results
Ryanrmueller
Send a private message to Ryanrmueller
I just finished up rebuilding the hydraulic cylinders on my d2 after the rust on the rod wrecked the seals. They are not chrome plated. Just bare steel.
Fri, Dec 29, 2017 9:26 PM
Oily rag draped over the exposed rods and covered with some sort of plastic or tarp if they are exposed to precipitation.
I have a similar situation I am not dealing with right now. I have an old forklift mast that was converted to mount on a tractor 3 pt hitch before I got it. It had been sitting out in the weather for 10 years or so but when I put some hoses on it and extended the single acting cylinder it came out looking pretty good and piston seal doesn't seem to leak. Only problem is i haven't gotten it to go back down yet so it is sitting exposed to the weather with the black steel rod out in the open. I have been painting it with oil every now and then but exposed like that it quickly disappears.
Fri, Dec 29, 2017 11:13 PM
Thank you received: 60
I winter wrap my exposed cylinder rods with PVC tape. The type used for wrapping gas pipe which is fairly thick. Kind of a PITA to do but does the job of holding back rust where the chrome is worn through.
Fri, Dec 29, 2017 11:34 PM
oldbeek
Disconnect the rods and suck them in? Nothing stops rust on the Oregon coast. Chrome tools in your barn will rust. Move to the desert. LOL
Sat, Dec 30, 2017 12:25 AM
bursitis
Reply to oldbeek:
i use wheel bearing grease for its anti oxidation properties. apply with a cheap paint brush.
Sat, Dec 30, 2017 1:32 AM
8C 361
Thank you received: 12
Reply to bursitis:
00 grease that is in your track roller pump is what we always painted plow moldboards with.
Sat, Dec 30, 2017 3:45 AM
Reply to 8C 361:
Grease rubbed on with disposable Gloves generally keeps them through a Wisconsin winter
Sat, Dec 30, 2017 6:39 AM
