Hyd control on d4
Hyd control on d4
Cat power
Send a private message to Cat power
G'day dose anyone know how much oil and what type is used in the hyd unit mounted on the front of a d4 mine only has 1 control
Thu, Jun 23, 2016 1:54 PM
Paso Bob
In the USA I use ISO or AW 46 hydraulic oil. The amount depends on how many lines you have and how far they run. A completely empty pump with lines will take 7-10 gallons. I just keep the tank full to the top.
Here is a link to more info:
http://www.hfifluidpowerproducts.com/Pages/Hydraulic-Fluid.html
Fri, Jun 24, 2016 10:49 AM
| Kingaroy, Queensland
