HY YELLOW
HY YELLOW
Showing 1 to 10 of 32 results
rturn3060
Send a private message to rturn3060
i KNOW THIS HAS BEEN DISCUSSED BEFORE AND I SHOULD HAVE TAKEN NOTES, BUT I NEED A SOURCE FOR HY YELLOW PAINT THANK YOU IN ADVANCE
Sun, Aug 21, 2022 1:08 AM
PNW.Hillbilly
Send a private message to PNW.Hillbilly
https://www.tractorpartsasap.com/caterpillar-highway-yellow-paint-gallon-156536.html
Sun, Aug 21, 2022 2:52 AM
Reply to PNW.Hillbilly:
Not for sale in California, go figure.
Sun, Aug 21, 2022 3:13 AM
rturn3060
Thank you Hillibilly, I am prepared for the n/a Ca regs.
Sun, Aug 21, 2022 3:37 AM
rturn3060
Reply to rturn3060:
Thank you Hillibilly, I am prepared for the n/a Ca regs. Petereson in klamath falls and Cashmen in reno both said 4C185 wasn't a good no.
Sun, Aug 21, 2022 3:59 AM
bruce oz
Thank you received: 23
Reply to rturn3060:
caterpillar 4C4185 fits Caterpillar® Hiway Yellow Paint, High Gloss
Sun, Aug 21, 2022 4:57 AM
Thank you received: 55
Reply to bruce oz:
all paint companies have old cat yellow as part of their equipment enamel line up. and you can buy sample cards from the acmoc store. it is still used however for school buses and the like as DOT highway yellow. safety yellow is also very close. any paint shop can mix the colour for you from formula. and is available in lead or lead free formulations.
the secret is dont over thin it. use good quality thinners or shellite. remember 3 coats to get a full colour. with enamels it helps to mix up 4lt of colour at a time a empty paint tin is useful for this to give more consistent results.
Sun, Aug 21, 2022 7:57 PM
side-seat
Reply to trainzkid88:
Finding a problem getting yellow paint for a D4 we're restoring right now.
Ended up using Rustoleum Caterpillar Yellow with some hardener added.
Mon, Aug 22, 2022 6:11 AM
sheddcanyon
Send a private message to sheddcanyon
Reply to side-seat:
what's the benefit of going with enamel as opposed to a single stage urethane (or two stage urethane for that matter)?
Mon, Aug 22, 2022 11:12 PM
rturn3060
Reply to sheddcanyon:
Hillibilly, Tallmans tractor supply is out of stock, found rustolium on internet at $101 but out of stock at $82
Mon, Aug 22, 2022 11:19 PM
d2gary
[quote="sheddcanyon post=240220 userid=12845"]what's the benefit of going with enamel as opposed to a single stage urethane (or two stage urethane for that matter)?
I tried single stage urethane when I painted my d2 and didn't have very good results.  The urethane was considerably more expensive also
 [/quote]
Tue, Aug 23, 2022 1:51 AM
