HT4 special parts for 40 scraper
tyoos
Send a private message to tyoos
My brother and I just were given a parts book from a friend for our HT4. We noticed that it showed a trans flow setup to use a 40 scraper๐Ÿ˜„ along with some other stuff using the same setup. Does any one have pictures of this setup being used for pulling a 40 pan? I've seen a couple on other machines but never hooked to the 40 pan. We would like to find one of these setups so if we get the 40 pan we are trying to get then why not hook it to the HT4 that doesn't get used alot. I've always wondered about doing this and know it's just a matter of finding the Trans flow valves. Whats special about the trans flow for the 40 scraper is it uses 2 of these valve setups one on top of the other. If any body knows of one let me know. I think it would be unique to see an HT4 hooked to a 40 pan as compared to a regular D4. I'll post some pictures of it from the parts book in a day or two. Any thoughts, help, or pictures on this subject would be helpful. Thanks, Josh.
1954 Cat D4 7U28304SP with cat angle dozer and Hyster D4N winch
1954 Cat D4 7U28174SP with cat HT4 lodaer
1953 Cat D4 6U with cat bulldozer
1946 Cat D2 5J8424SP with Traxson T2 loader 624 and canopy
1954 Cat D311 4V6821 Gen Set
1946 Cat D4400 1S4444 Power Unit
1959 Mack B421 semi tractor with 413 Chyrsler engine
International R190
1939 International D2 pickup truck
Lei Roi Tractair aircompresor
Clark airport luggage truck
1947 Farmall A
1946-1977 20 Gravely Lawn and Garden Tractors
Wed, Mar 3, 2010 1:11 PM
Rd6 plower
Send a private message to Rd6 plower
The 40 scraper requires 37 GPM's for cat specs and I wana say 1200 PSI for it to run correctly.
And really you could put pipe t's and ball vavles and that would be the same as cat cross over valves but not factory but functional.๐Ÿ˜„
Wed, Mar 3, 2010 2:36 PM
Reply to Rd6 plower:
About the only likely place you will find the stacked transfer valves is on a unit with the HT4 factory scarifier. Same set up used for a tool bar or #40 scraper on the HT4.
Wed, Mar 3, 2010 11:03 PM
