HT4 D4-7U Hydraulic Question
Skip in CT
Send a private message to Skip in CT
Here is the problem, I have a model 44 hydraulic unit and the number on the tag is 7W7721 and I am leaking oil from the control levers. The Cat dealer here faxed me part breakdown from a 6F500 and a 4F8881 (the 8881 is questionable because of it being a fax) and both show only one control lever. Am I missing something or is this all I have to work with?
I guess if the tank cover gasket is available I should just dig into it and see what the seals are and match them best I can.
Any help is always appreciated, Skip in CT
Thu, Aug 18, 2011 12:24 AM
There should be lots of info in the old post archives.....if you can make it work, as this has been discussed many times.
Thu, Aug 18, 2011 12:34 AM
Skip in CT
Thanks OM, I found where you posted the seal numbers last year. I will get a gasket from CAT and seals from a local guy and dive into it.
Skip in CT
Thu, Aug 18, 2011 4:05 AM
CATCURT
Send a private message to CATCURT
Reply to Skip in CT:
Skip in CT
The seal numbers from cat are
1J2382 large seal
9F3847 small seal
4F4217 gasket for cover
I have replaced mine and they leaked so I did it again and installed 2 seals in each place and no leak. The original seal had 2 sealing lips and the new one only has one. Good luck
Thu, Aug 18, 2011 9:01 AM
Reply to CATCURT:
1J2382 large seal
9F3847 small seal
Should be a lot more info in old posts, including some quite recent.
In any event, get in to it and I'm sure any info you need can be supplied again.
Thu, Aug 18, 2011 9:24 PM
JAKEcatHT4
Send a private message to JAKEcatHT4
yeah I performed this same task last year and might have started a thread. I got lucky and sealed it up with one of each size. The seals can be cross referenced and purchased from a bearing, belt supply house. I went as far as getting into the pump valve mechanism and replacing some o rings. Was hoping to improve the performance of the slow hyrdraulics but may have focused on wrong area..oh well got it back with new o rings anyways..good luck, pretty simply job except for fumbling all those cover bolts
Tue, Aug 23, 2011 10:29 AM
