HT4 D4-7U Fuel Question
Skip in CT
Send a private message to Skip in CT
Are the fuel shutoffs under the tank a 1/4 turn shutoff like a gas cock? I turned the drain one a few turns but it did not stop turning and I don't see a line on the square to indicate the flow passage. If it is not a 1/4 turn how many turns should it take to shut it off?
Skip in CT
Mon, Aug 1, 2011 8:34 PM
They are 1/4 turn valves but can be difficult to determine position. I change mine out for ball valves.
Mon, Aug 1, 2011 9:21 PM
64farmboy
I agree, I changed mine to ball valves as well, don't need to see them to know when you've got them shut off
regards Dennie
Mon, Aug 1, 2011 11:10 PM
Reply to 64farmboy:
regards Dennie
On my D2 once i found out the position for full flow i took the edge of a file and cut a line on the square head for that direction. 👍
Tue, Aug 2, 2011 12:21 AM
Skip in CT
Reply to dpendzic:
Thanks for the replies, I will have to crack the line now to determine the open position, then I will mark it.
Skip in CT
Tue, Aug 2, 2011 3:21 AM
