HT4 D4-7U Brake Adjustment
Showing 1 to 10 of 12 results
Skip in CT
Send a private message to Skip in CT
I am trying to adjust the brakes on my machine. I did them 4 years ago and it needs it again and I don't remember what I did. I have the access cover off and there is a adjustment bolt head on the brake band that I tried to turn but it won't budge. Is there something locking the adjustment or are they frozen?
Skip in Ct
Wed, Aug 3, 2011 5:59 PM
ol Grump
I don't remember a locknut on the brake adjustment but they have detents that will hold the nut at every 1/6 turn. If you can't turn the nuts, they may be frozen with rust. ."loose juice" and maybe a bit of heat on 'em should loosen 'em up.
Then there's the brake band support bolts . . with the brake pedals depressed, tighten 'em and then back off a turn and a half and tighten the lock nuts.
Wed, Aug 3, 2011 8:37 PM
Skip in CT
Reply to ol Grump:
Thanks ol Grump I will try to some heat if I can figure out where to heat. I cant see any threads that go into a nut but I will look harder. Is the nut on the end of the furthest band looking down the adjustment bolt?
Skip in CT
Wed, Aug 3, 2011 9:13 PM
ol Grump
Reply to Skip in CT:
Skip in CT
As you look down the adjustment rod with the hex on the top, you'll see the fork attached to the brake band. .the actual threaded nut is below that, it's several inches long. With just the clutch/brake access covers off, it may be rather hard to reach. If you can't reach it to heat it, you might try tapping on the end of the adjuster. If your critter has a seat tank it may be even harder to reach as you're working through the hole the tool box sits in.
Thu, Aug 4, 2011 8:41 PM
Skip in CT
Reply to ol Grump:
ol Grump I was able to get the adjustment to move with a 1/2" ratchet instead of 3/8 also a good soaking of loose juice over night helped. I did finally take the seat tank off to gain better access to everything. It's all adjusted up the peddles don't go o the floor but still not great breaking. If I pull the track levers back the mackine will stop so I know they are releasing but on a down hill sometimes tough to turn. Can the brake bands come out for relining after taking the top off the rear housing but without removing the drive line?
Thanks again your all so helpful with this old equipment.
Skip in CT
Fri, Aug 5, 2011 2:53 AM
ol Grump
Skip in CT
Skip,
There's no drive line in there as such, just the cross shaft the drums, clutches and crown gear mount on. The bands can come out w/o taking the cross shaft out by taking off the tranny cover. Also, the SRB says that the bands can be removed w/o taking the tranny cover off. Maybe is all I'll say about that if you have small paws 😆
Before you go any further, you might try washing the brakes first. Drain the brake/clutch compartments, replace the plugs and dump in enough kerosene or diesel to touch the lower part of the brake drums, then drive the critter back and forth a few minutes w/o releasing the clutches, then drain and let dry.
If that doesn't help the problem, then it's time to pull the bands.
Fri, Aug 5, 2011 8:51 PM
Skip in CT
Reply to ol Grump:
Skip,
After adjusting the brake a few times I finally decided to reline the brake bands, so I took the top plate of the machine off to remove the bands. I don't have any books on the machine so I am relying on just mechanical skills (a explode view would be great). Anyway I removed the adjustment nut and jacked out a pin anchoring the band but still can't remove the band. There is another smaller pin in the casting pocket with cotter pins holding it in place that seams to be frozen, does this have to be removed in order to remove the band? I'll bet this was real easy when the parts were new.
Skip in CT.
Tue, Apr 23, 2013 12:49 AM
Skip in CT.
My SRB says there are 3 sections to the brake band, top,center,and lower.
There is also an inspection cover to the rear of the steering clutch case that needs to be removed to gain access to the center and lower sections of the brake band
Tue, Apr 23, 2013 2:16 AM
gemdozer
Thank you received: 25
Reply to dpendzic:
You need to loosed the support bolt under the stering cluch housing for turning the brake band.
Tue, Apr 23, 2013 4:19 AM
Kelly
Reply to gemdozer:
Skip,
On some tractors the lowers section of the brake band cannot be removed without first removing a portion of metal located adjacent to the reverse idler gear bracket bore. Just remove enough metal to allow sufficient clearance to remove the lower section of the brake band
Kelly
[attachment=17314]D42Tbrakebandremoveal_chipoffmetal..jpg[/attachment]
Tue, Apr 23, 2013 5:36 AM
Inter674
Reply to Kelly:
Skip,
Kelly
I have to agree, in theory this is easy but in practice it is a PIA because the components are usually all rusted up and some of the locating pins are in impossible to get at locations. I ended up basically destroying the lower brake band actuating/locating pins on mine because they would not slip apart. Luckily I had spares. I did note that they were not original anyway - they were made from bolts drilled for a split pin - so some one else must have had the same problems beforehand😊
And please do not talk about removing the worn the brake cross-shafts from the rear casing - now that really is an impossible task. Mine simply stripped in the threaded hole provided into which a puiller is inserted. I ended up welding another bar onto the end of the ones in situ and with a massive slide hammer arrangement and lots of heat and loose juice everywhere, they eventually came out - but ruined in the process. I can see why nobody pays the brakes any attention until they are all completely buggered up and generally beyond saving!
Tue, Apr 23, 2013 7:46 AM
