How wide is the blade on the new D9E model?
Joseph Zimmerman
Send a private message to Joseph Zimmerman
Hoping it will fit in my D9E CCU case
Sat, Nov 29, 2008 10:56 PM
Joseph Zimmerman
any know how wide the blade is?
Tue, Dec 2, 2008 7:25 PM
OzDozer
Reply to Joseph Zimmerman:
The original D9E 9S blade is 14' 1 1/8" wide. If the scale is 1:25 and accurate, that makes the blade on the model, a whisker over 6¾" wide - 6.765" to be precise.
Tue, Dec 2, 2008 7:48 PM
Joseph Zimmerman
Reply to OzDozer:
Oz- Thank you for very much for your calculation and your information.
Incidently- I just found an old blueprint of my Father's for a D9G blade guard and it shows that the blade width for the G Series (Semi-U) is 13'3"---guess they shrunk it a little for the next series!> I will be posting the print and photos as soon as I get them scanned.
Thank you again for doing this.
JZ
Wed, Dec 3, 2008 10:41 AM
OzDozer
JZ
Joseph - That is an interesting design change you've noted. The D9E and D9G straight blades were both Semi-U design .. but the D9G blade was the first to feature the torsion bar arrangement behind the blade that took the stress off the blade, the blade braces, and the sidearms when tilting the blade.
I would presume that the narrower blade was part of the redesign when this was done. The difference in width between the "E" and "G" blades is quite surprising.
My 1961 blade spec sheet says 13' 5¼" for the D9G, 9S blade width. I would put this down to differences in end bit design.
The early blade end bits were just flat section .. the later ones were a heavier cast design with a raised and thickened corner that was angled outwards a little more than the original flat end bits .. thus accounting for the additional couple of inches.
Wed, Dec 3, 2008 1:51 PM
Joseph Zimmerman
Reply to OzDozer:
Oz- I sent in some scans for an article in the magazine.
One of them is a partial of a blueprint my Dad had drawn up for a blade guard design for the 9. It has a lot of measurements on it for the existing blade, plus those of the guard. (pictures of the mounted guard are included for the article)
If you are interested, I could make a copy of it so you would have the full drawing.
Fri, Dec 5, 2008 9:03 AM
| Kingaroy, Queensland
