How to test glow plugs
Showing 1 to 10 of 12 results
bcwayne
I added another kitty to the fleet today... D2 5U183xx... placed into service in April 1957 working in the orchards in the San Joaquin Valley of California.
Its my first factory equipped direct electric start with glow plugs...
I have two questions: how does one test each glow plug to insure that its operating as designed ??? ( the amp gauge does show a healthy discharge when activating the pre-heat switch )
How long should I have to heat the glow plugs before starting the engine when the ambient temp is 40 to 50 degrees F ???
Thanks, Wayne
Sun, Apr 4, 2010 9:55 AM
KCB
Send a private message to KCB
bcwayne;
Nice tractor. It also has the rear #41 Hydraulic unit.
Each glow plug should pull about 7 amps (28 amps for all four). You can disconnect the wiring at the top of the glow plugs, then plug only one in at a time and check the current draw. Do this individually for 1,2,3, and 4, if each test shows 7 amps then each is working. Another crude test is to disconnect all wiring at the top of the glow plugs, hold the heat switch on, then touch the wire to each glow plug - if you see a spark it is most likely working. The starting instruction decal shows the following:
Above 60 F ... No heat switch needed
60 to 45 F ... Heat on 45 sec
45 to 32 F ... Heat on 1 min
32 to 20 F ... Heat on 2 min, plus use 1 either capsule
20 to 10 F ... Heat on 3 min, plus use 2 either capsules
My experience in 40 - 50 F weather is to use 1 minute, I usually time it with a clock. At the time it seems like a long time, but it is of little value to go much less than 1 minute. Once the engine has run a while, if you do a shut off and a second start within 4 hours, you probably won't need to use the heat switch.
Sun, Apr 4, 2010 10:31 AM
bcwayne
Reply to KCB:
bcwayne;
KCB, Thanks for the information... I wouldn't have thought it necessary to pre-heat for a minute or more.... I'm used to the modern day diesel in my pick-up truck that takes only a few seconds to pre-heat. I need to get some new batteries and when it stops raining I'll give her a try. Wayne
Mon, Apr 5, 2010 8:57 AM
Dunefanatic
Send a private message to Dunefanatic
Reply to bcwayne:
Nice Ride Wayne! Very straight tractor. I have to ask what the two little fittting looking thingies located under the battery disconnect switch on the firewall are? I have never seen a Cat 41 pump on the rear of a D2 so that picture was very illustrative.
Kent is correct that I have found on my direct start after it had the new glow plugs and injectors installed, when starting I get a guaranteed quick start when I pre-heat the glow plugs for a minute and leave the glow-plug switch on while hitting the starter switch.
Greg
Mon, Apr 5, 2010 10:48 AM
side-seat
Thank you received: 15
Reply to Dunefanatic:
Greg
The thingies look like the place you put an ether cartridge in and press down to puncture them.
Mon, Apr 5, 2010 8:03 PM
ronm
Reply to side-seat:
Have to tell my glow plug story-back in the 70's I was at the JD store, & the ol' grouchy-ass parts man came back into the shop w/a glow plug out of a 2010. Asked how to check it, so I gave him a couple jumper wires & showed him how to hook it to a battery...about 30 seconds later a string of profanity issued from the area of the charger bench, & the plug flew across the shop...I asked, what happened, Bill? He said "That SOB got red hot right where I was hangin' onto it!!!" I said, "Well why do you think they call 'em glow plugs?" He swore I did it on purpose, but I never had any idea he'd hang on to the hot end...😄 Gave everybody in the shop a good giggle, anyway...
Mon, Apr 5, 2010 10:24 PM
jmvmopar
Reply to ronm:
Just unhook the wire to the glow plug. Connect a test light to battery + (assuming a - ground system of course) and touch the test light to the terminal of the glow plug. If the test light lights up the glow plug is good.
Tue, Apr 6, 2010 10:08 PM
bcwayne
Reply to jmvmopar:
Installed new batteries... pre-heated for one minute... and she fired right off. Life is Good.😊
Tue, Apr 13, 2010 4:52 AM
Soapy
Send a private message to Soapy
Reply to bcwayne:
Wayne, the plugs in your modern diesel pickups are 6-volt, that is why they heat so fast.
Wed, Apr 14, 2010 11:59 AM
83Jim
Send a private message to 83Jim
Reply to Soapy:
Since the machine starts the issue is pretty much moot but, my understanding is that most Cat glow plugs of that era draw 5 amps each. If the machine has a working amp meter it should indicate 5,10,15 or 20 amps discharge depending on the number of plugs working.
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Thu, Apr 15, 2010 7:50 PM
chriscokid
Reply to Soapy:
BC wayne,
I noticed that in one of your pictures, that after you run your cat a while you can cook your lunch on the fender😊
Thu, Apr 15, 2010 8:15 PM
