How to split tracks on D6
Showing 1 to 10 of 27 results
JJP
Send a private message to JJP
I need to know how to split and remove the tracks on a D6 9U?
Sun, Dec 20, 2009 10:04 PM
gemdozer
Thank you received: 25
You need to find the master pin and move the dozer until the master be near the sprocket and with a sledge hammer you hit the master pin until she is out.
Mon, Dec 21, 2009 2:06 AM
SJ
Send a private message to SJ
Reply to gemdozer:
Gemdozer, he needs a pin (big bolt, shaft) a little smaller than the master pin to hit against the pin to drive it out.We used to weld a big diameter piece of cable to the driver (pin) so you didn,t get hit with the hammer and also relieved shock from hitting the driver.
Mon, Dec 21, 2009 4:20 AM
Reply to SJ:
The driver needs to be soft enough not to shatter off bits when you strike it with a sledge. Bolts are a good candidate. You might get by with some cold rolled shafting for a few uses. I would stay away from axles etc.
The master pins are usually marked by a dimple in the ends. If you can't get it to budge, then heat the links a bit with a torch.
Mon, Dec 21, 2009 7:59 AM
JJP
Thanyou a lot guys
Mon, Dec 21, 2009 10:00 AM
OzDozer
JJP - You need to determine the type of master pin retention you have. Cat used three types of master pin retention over the decades. Early style of master pin retention involves a tapered plug that has a threaded hole in the center. Then Cat went to a tapered plug that was just hammered in and out. This was a relatively short-lived idea, before the design was altered to a solid pin that is just a .003" or .004" interference fit in the links.
Your tracks will have a solid pin if the track chains have been replaced after the late 1950's/early 1960's. Here are the pages from the manual, detailing the two early types of master pin design and plug removal.
Page 154 .. http://i50.tinypic.com/25k4kdf.jpg
Page 155 .. http://i48.tinypic.com/33dh3qa.jpg
Page 156 .. http://i48.tinypic.com/dh6fea.jpg
Cat suggest moving the master pin to the front of the tractor, and using the front idler as support. This is a matter of personal choice, or ease of access. My personal choice is always the sprocket, as Gemdozer suggested. The sprocket offers more solid support when hitting.
Here is my method, that I have used for 45 years, and which always works for me.
You locate the master pin, and back up until the sprocket is approximately at knee height, or a little lower. Place a hardwood block on end against the grouser near the sprocket. Back up until the track is firmly lodged against the block, and the sprocket teeth are solid against the bushing. Lock the brakes.
Slacken the track right off by unscrewing the track adjuster or by releasing the pressure in the hydraulic adjuster, if fitted. Make sure the front idler moves fully rearward. If the idler is sticking in its guides, move the tractor forward and place a pin in the top of the sprocket, then back up until the idler is pulled right back. Reposition the tractor against the block again, as above, if you have to do this.
Remove the plug/plugs as shown in the manual pages, if the master pin has a plug or plugs. If there is no indication of plug or plugs, and only a dimple is showing, then you have the solid master pin. It's not critical that the shoe be removed. Shoe removal helps with access .. but the shoe, when bolted up, helps hold the links firmly.
Acquire or fabricate a steel drift, just slightly smaller diameter than the master pin. Attach an L-shaped handle to it. Heavy wire rope welded to the drift makes a good shockproof handle. It's a good idea to chamfer the ends of the drift to avoid metal spalling and chipping. Mild steel is satisfactory for a drift .. but I found that old truck axles are best. A small 45° chamfer with the gas axe on the drift softens the metal and helps prevent chipping.
Now for the important part. It is CRUCIAL that you support the track link from the rear to prevent the track chain from bucking, and thus absorbing all your hitting impact. Support the rear link with a very heavy long bar, a bottle jack supported from the drawbar or a solid part of the final drive housing, or just hardwood blocks driven into the gap between the link and the tractor rear housing.
Lube the master pin and link area with your favorite panther pee (penetrant). Select your finest 14 lb or 20 lb sledgehammer (depending on your size and enthusiasm - I'm only a little guy, and a 14 lb'er is plenty for me .. 😄 ). Get an acquaintance to hold the drift.
WEAR SAFETY EQUIPMENT .. safety glasses, face shield if so inclined, and some leather protection for vital body organs. Flying steel chips are no respecter of a persons vital organs. Start hitting the master pin with seriously accurate hits. Accurate hitting minimizes steel chipping and makes the pin really move. If the drift shows signs of serious belling over, gas-axe the overhang, and chamfer the edge again.
The master pin should commence to move from the first hit. If it doesn't move after 5 or 6 hits, you may need to consider warming the links with the gas axe. Use a large rosebud and re-commence hammering the pin before the heat soaks into the pin too much.
The master pin has a center section that is reduced in diameter, for link clearance ..so you only need to move the section of pin that is the width of the link, for it to suddenly shoot in several inches. Then you need to hammer it through the rear link, where the clearance is reduced to interference fit again. Good luck, let us know how you get on.
Mon, Dec 21, 2009 10:03 AM
Rd6 plower
Send a private message to Rd6 plower
Reply to OzDozer:
When you go to put it back together. Put the master pins in the freezer for 48 hours at least that way the pins shrink so they are easier driving in. My Grandpa Joe used to do that. Well good luck fellow CAT lover!!! 😄
Wed, Dec 23, 2009 12:52 AM
Gordon.
Send a private message to Gordon.
Reply to Rd6 plower:
We allways split the track at the idler, our preferance. On reassembling i feel the sprocket hinders chain movement allthough it can help to hold the track together whilst driving the pin in. Oz we havn't tried to break the chain at the sprocket on an elevated unit yet.......maybe after a beer or two it would make an interesting job lol
Gordon.
Wed, Dec 23, 2009 2:32 AM
tctractors
Reply to Gordon.:
Gordon.
A Big thing to do before you start any Hammer action is to "slacken the track", I myself always split the chain on the front Idler on everything with links, its just the way I do it.
tctractors
Wed, Dec 23, 2009 2:25 PM
OzDozer
Reply to tctractors:
tctractors
Ooops, my error .. I forgot to write in, that you slacken the track adjuster right off, before you commence any pin removal. I have done it so often, I just sort of presumed that anyone else would know to do that .. but no doubt, some people wouldn't. I've amended the instructions accordingly.
Wed, Dec 23, 2009 2:33 PM
gemdozer
Reply to OzDozer:
Me I adjusted the track solid before removed the master pin and when you hit the pin there are no rebound on track and you need a 16lbs sledge hammer
Wed, Dec 23, 2009 9:51 PM
