How to get to Image Shack?
Showing 1 to 6 of 6 results
Delta Dirt
Send a private message to Delta Dirt
What is the process in using Image Shack??
I presume that this is a site that you subscribe to for use of----keep hearing about it but never have tried accessing it.
Any coaching appreciated.
-----and I do appreciate the thumbnail size photos due to my slow load up feature from the dial up connection. Let's give Joe some time to "fine tune the piano". Gotta walk before we run----at least we are past the crawling stage.😎
On the old board, on many of the full size pictures----it took so long to download that I would finally just have to skip over them (or view only the top 1/3----guess at what the rest of the picture must have shown).
Great progress has been made here-----be patient----and it will get better.
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
Wed, Nov 29, 2006 9:05 AM
gwhdiesel75
try www.imageshack.com; or
try www.imageshack.us
one of them should work. GWH
Wed, Nov 29, 2006 9:13 AM
gwhdiesel75
Reply to gwhdiesel75:
I just tried it and for a beginner, it would be www.imageshack.com
GWH
Wed, Nov 29, 2006 9:16 AM
OzDozer
DD - ImageShack upload page is here .. www.imageshack.us
It's simple enough to use .. left click on the "browse" button .. which opens you default picture files window ("My Pictures" in Windows XP) .. select the picture you want to upload .. left click on "host it!" ..
After a few seconds, you'll see a thumbnail appear, with a number of address "codes" above and below it. These codes are listed for putting the image up on .. websites and forums (BB's) .. and you can select either a thumbnail code or full size codes.
All you need do, is highlight, copy and then paste the selected code into your posting on any BB.
The bottom code gives you a direct-linked, full size image in your post.
The headings along the top are links to more info .. click on and read the "Common Questions" for starters ..
Once you have pics hosted on there, they stay there forever .. and you can find them, by left clicking on "My Images" at top right of the page.
"My Images" page has a list of images (or you can select thumbnails if you prefer) .. and left clicking on "Get Code", gives you the codes for that pic.
If you look up Swishys picture posting advice on the ACME "Help Forum" .. you'll find his instructions very helpful ..
http://www.antiquecaterpillar.net/ACF_v2/forumdisplay.php?f=8
Wed, Nov 29, 2006 9:22 AM
bruce oz
Thank you received: 21
Reply to OzDozer:
hello all , i found photbucket better for pic hosting if you want them in a album,on image shack you can make an album ,but if you lose the link you cannot upload more pic to that album,in phot bucket you just open the album and add new to pic ,i have over 60 pages of pic on imageshack and there hard to find one pic when you need it ,photobucket you just open album up to find them ,hope this helps ,bruce oz
http://photobucket.com/
Wed, Nov 29, 2006 10:05 AM
Thank you received: 22
Reply to bruce oz:
Hi Bruce/Oz,
Thanks for the "heads up" on photobucket. I sort of fell into the habit of using imageshack but it is a little difficult to navigate in when you have a lot of material posted. Will give it a go.
Thu, Nov 30, 2006 12:04 AM
§wishy
Send a private message to §wishy
Hi Bruce/Oz,
[COLOR="Blue"][CENTER][b]Herez the animation I did sum time back on useing Imageshak
the only difference B tween then n now is the image size can now B 1500kb (1.5meg)
SoWatchIt[/COLOR]
[img]http://img9.exs.cx/img9/4401/imageshackturtorial2py.gif[/img]
[/CENTER]
cya
§wishy
HasBeen[/b]
[CENTER]🙄 - : [B]ButEyeDoSt&2BCorrected : - 😛
Ifn U Get my Drift[/b]
😮 [/CENTER]
Sat, Dec 2, 2006 12:34 AM
