How to find the library?
GrantJ
Thank you received: 7
This is the first time I have looked for the library since the web site was changed, and I cant find it. I know it has been discussed many times before, but my question is for direct start for my D2 5U. It is factory drilled so that part is easy. I hope to do it in 12 volt rather than 24V. The few I have seen advertised are 24 volt and pretty pricy. I am not opposed to finding the correct nose cone and going to a truck wrecker to find a 12 volt unit. Any advice????
Thu, Jun 19, 2025 4:47 PM
Mschwartz
I think that if you go into the members tab and then scroll down you will find the library tabs on the lower right side of screen. I also have a question, how do you start a new discussion topic? Thanks, Mike
Thu, Jun 19, 2025 4:53 PM
GrantJ
I found the library. Thank You! When I click on discussion and it pops up, there is a small black square with white lettering just above the first post that says "New Discussion" It stands out pretty clearly on my screen. Have fun. Thanks Grant.
Thu, Jun 19, 2025 5:03 PM
