How start cat 955 h loader...24volt??
NIK O.
Send a private message to NIK O.
For cousin i'm helping...4 cy, turbo, power shift...has master sw/key, by r heel, w/ small lever beside...only i 12 v., # 4 dlt batt @ rear hole, non by driver, ends cut off there...looks like glow plugs?? Dash like my d6b 37a had...where do shifters set, to start?? On xmsn dipstik, one mark below #4f 719...where is full? Two fillers, one belo ser, one belo dash...same fluid?? Youze guys got filter #s, fuel/oil/trans/hyd?? How full on side hyd tank, on r? Acmoc sent me my birthday hello, today, age 77...
Be blessed, grateful, prepared, nik
Thu, May 16, 2019 4:38 AM
Is it factory direct electric start or conversion? Different flywheel ring gear, straight cut vs helical used with pony start.
That's not correct plunger (dipstick) for the trans. should be a part number 8M8496.
Start position would be NEUTRAL, ( bottom of "U" shift pattern).
Filler below engine s/n is crankcase engine oil.
Filler below dash is transmission oil, use transmission drive train oil TO4 spec.
Starter and glow plugs would be 24V.
I don't believe there is a sight glass on the hydraulic tank. If so just fill to withing sight of the filler screen.
What's the s/n of the machine?
Congratulations on the big "77".
Thu, May 16, 2019 11:28 PM
NIK O.
[quote="old magnet"]is it factory direct electric start or conversion? Different flywheel ring gear, straight cut vs helical used with pony start.
That's not correct plunger (dipstick) for the trans. Should be a part number 8m8496.
Start position would be neutral, ( bottom of "u" shift pattern).
Filler below dash is transmission oil, use transmission drive train oil to4 spec.
Starter and glow plugs would be 24v.
Congratulations on the big "77".[/quote]
thanks, om
Fri, May 17, 2019 12:36 AM
