How much will match?
Tim Matthews
Send a private message to Tim Matthews
Im looking at a D-7 for parts and maybe run again. My D-7 I have now is serial number 3t-26208 the one I am looking at is a d-7 17a 11438 . It doesnt look to be turbo charged. I mainly am looking at the pulling winch on the rear and the c-frame and angling blade . But I also might try to get it going .Locked up , You know the story , running when parked. So who knows what is on the inside. Wondering how many parts will interchange with my 3-t . Thanks Tim
Sun, Sep 17, 2017 4:25 AM
Thank you received: 140
Hi, Tim M.
The experts will likely be along shortly to 'corr-wrecked' me if I am wrong but I think the winch and the blade will certainly interchange and much of the other 'stuff' will too, even down to the main frames and tracks. As I understand it, it was around the change from 3T to 17A that the blade lift went from 4 falls of rope to 6 falls, which meant different sheave blocks top and bottom of the blade lift but I think the actual sheave blocks will interchange from one to the other.
The 17A engine was a little more 'grunty' and there may have been some slightly different ratios in the transmission.
Sun, Sep 17, 2017 5:54 AM
Tim Matthews
I looked up old conversations and it doesnt look like a whole lot matches but some does. So now I have to figure whats the blade and winch worth to me. After adding moving the machine costs.
Sun, Sep 17, 2017 6:00 AM
Tim Matthews
Reply to Tim Matthews:
I wonder if the main clutch is the same? And thanks for all the replies Tim
Sun, Sep 17, 2017 6:05 AM
Tim Matthews
Hi, Tim M.
[quote="Deas Plant."]Hi, Tim M.
Just my 0.02.[/quote]
Hi Mr. Deas Plant ; They are both hydraulic I wonder if the cylinders and pump are the same ? Thanks Tim
Sun, Sep 17, 2017 6:14 AM
Tim Matthews
Looking at my posts Im doing a lot of wundering . Lol
Sun, Sep 17, 2017 6:16 AM
