How many hours did the big cat motors last before a rebuild?
Showing 1 to 10 of 13 results
DrewAbt
Send a private message to DrewAbt
I was just wondering how many hours was common on the older workhorse machine before a engine rebuild? I’m talking a hard working machine that was used to make money and serviced like it should be. My only experience with old diesels is international farm tractors and they would routinely hit 10,000hours before an overhaul. But not always. Also which ones seemed the best for longevity? D333,D339,D342 etc. And also was there any common failures that seemed to haunt a certain model?
This question is sparked from my last thread regarding oil consumption in my D7E. I like to think that these old monsters could run forever if kept up but I know they do have there limits LOL
Thanks in advance.
Drew
Tue, Jan 1, 2019 8:42 AM
Got around 14,000 hrs when overhauled, D339. I have seen in old cat brochures, tractors or power units getting 30,000 hrs. All depends how they are warmed up, ran and cooled down before shutting off. And use a quality oil, check air filters, clean radiator fins, coolant changes and additives.
Tue, Jan 1, 2019 8:52 AM
DrewAbt
I’m guessing you overhauled it because oil consumption was way up and power was dropping off?
I seems like the power units would always go twice as long as a tractor. Unless they were constantly ran in a very hot location.
Tue, Jan 1, 2019 9:05 AM
oldbeek
Reply to DrewAbt:
I managed a fleet that had, 11 1967-68 yr mod 12s. I ran them to 14,000 hrs using oil samples to make the decision. Then ran them 14,000 hrs more before selling them. Every internal bearing and gear was on the verge of failure at 28,000 hrs. Lots of chrome in every box. They are probably still getting occasional use out on some ranch now.
Tue, Jan 1, 2019 9:40 AM
Casey Root
Reply to oldbeek:
A neighbor ran a D333A in a D6C 74A farm tractor. At 18,000 hrs, 1 piston, valve job, rings and bearings and away they went. The mechanic that was hired was known to be overly persnickety, so they probably could have gotten by without the piston change.
When the AG tractors switched over to the dry air cleaners, the expected engine life went up dramatically. I have heard or D7E, 47A's and D8 36A's regularly getting over 25,000 hrs.
Wed, Jan 2, 2019 12:19 AM
Bruce P
Thank you received: 38
Reply to Casey Root:
It’s not a big Cat, but our 7U has over 14,000 hrs without being apart. Burned a little oil but not terrible. We simply out grew it. My BIL owns it now and it sees occasional dozer work.
BP
Wed, Jan 2, 2019 12:36 AM
seiscat
Reply to oldbeek:
Hi DrewAbt, your posts are interesting. I don't know the level of your experience so please forgive me if I post info that you already know. I have seen too many examples of old Caterpillars being abused, Rome K/G's post about starting engine abuse is one. These pages are also from the D7E Operation and Maintenance Instruction book:
[attachment=52066]IMG_0002.jpg[/attachment] [attachment=52067]IMG_0006.jpg[/attachment]
I included them because following those instructions increases the longevity of both engines. Changing the oil in the starting engine is very important and should be done often, oil is cheap compared to overhauling or replacing the pony. Shutting the pony down by turning the gas off is very important.
The most critical factor in determining when to overhaul the engine is oil pressure. The D339 is happy using some oil as long as oil pressure isn't falling off too much during the day. I saw a D7E cooled down and shut off at high idle (the turbo just loves that). When I asked the operator why he did that he said that if he idled it down any lower the oil pressure went into the red so far that he couldn't speed the engine back up! :doh:
Craig
Wed, Jan 2, 2019 1:02 AM
Reply to seiscat:
Craig
Thanks for sharing that Craig. Gary
Wed, Jan 2, 2019 1:05 AM
DPete
14K hours seem to be a common goal, that's what we figured for the D342 if nothing happened to cut it short. A couple hidden gremlins were the oil pump drive coupling could wear dangerously thin and the center main ( thrust Main) could turn with age and shut oil off to the #3 rod.
1962 D4C
Wed, Jan 2, 2019 1:37 AM
Pioneernorth
Send a private message to Pioneernorth
Reply to DPete:
3304 in skidder at around 15000 hours.Wasn't really wore right out. Idler bushing on gear train went and whole bunch of rattling started. I have a Mack E7 with almost 25000 on it and bottom never touched. Many modern logging machines will get run up around 15 to 16000 hours before they go to Ritchies. When I logged in the cold winters of a bygone era nothing got shut off for more than a quick service for the complete winter. I wonder if the true hours on some of those old Cats isn't more like 50000? Just thinking the age and if they had an active career.
Wed, Jan 2, 2019 2:09 AM
Reply to DPete:
Good to tear down and inspect, than have a major failure. Oil sampling is very good preventive maintenance also.
Wed, Jan 2, 2019 2:14 AM
