How do you like your seat? Stock or no?
Showing 1 to 10 of 11 results
Barely Smokin
Send a private message to Barely Smokin
The seat on my D4D 83J2646 is toast, including some pretty good rot on the bottom plywood piece. There's also a big rip in the back cushion and my armrests are missing. Local shop wants $130 just for a replacement bottom cushion. I like stock...but you can get a decent sprung seat from Tractor Supply for $100.
http://www.tractorsupply.com/agriculture-farming-ranching/tractor-tune-up-repair/tractor-seats/farm-tractor-replacement-seat-black-0278205
Do you guys like the stock bench seat?
What about armrests? Would you get a replacement "captain's chair" with armrests or do you like the bench set-up and armrests?
I was thinking the armrests on a replacement seat would be too narrow for the controls and stuff.
D4D 83J2646
JD 790
JD 440
Wed, Jan 20, 2010 6:36 AM
SSsssteamer
Send a private message to SSsssteamer
Personally on my D4 7U, I replaced the original seats with original type again, with no arm rests, and only with the side cushions on the arms. On the larger Cats like my D8 14 A, again I went with stock seats. They worked well originally and Cat had that in mind when they were first installed. On my new John Deere tractor/loader, I have air suspension for my seat and that is really nice when I am traveling. When I am working in the gravel pit, air suspension doesn't really make much of a difference.
Wed, Jan 20, 2010 12:50 PM
Rd6 plower
Send a private message to Rd6 plower
Reply to SSsssteamer:
Go stock, that's what we Run on all our stuff and we get the cat cushions from John Hahn. His stuff is way more comfortble then the original cushions but looks the same or better. I highly recommend him!๐Ÿ˜„
Well good luck fellow CAT lover!๐Ÿ˜„
Wed, Jan 20, 2010 2:33 PM
Barely Smokin
Reply to Rd6 plower:
Thanks, guys. Somehow my search on the BB missed the December conversation about John Hahn's seats. Got it now.
I can't dump $500 into a seat. But I checked out some aftermarket seats and they're just cheap Chinese garbage. Can't do it.
Guess I'll rebuild the one I have....
D4D 83J2646
JD 790
JD 440
Wed, Jan 20, 2010 9:45 PM
Frank Fox
Send a private message to Frank Fox
Reply to Barely Smokin:
The price you got locally was cheap. I spent $300.00 locally for seats for my RD-6 and I made the new boards and furnished the foam. Next time I will use Hahn seats.
Call John Hahn and work something out, you will be happy you did.
Just my thoughts
Frank๐Ÿ˜Š
Thu, Jan 21, 2010 10:21 AM
Mike Walsh
Reply to Frank Fox:
Just my thoughts
Frank๐Ÿ˜Š
If you want to deviate from a stock seat, you might look at K&M Manufacturing. The seats they sell are best suited for wheel tractors but some would easily adapt to a crawler. Many of their seats are made in USA. I have had good luck with the ones mfg here. K&M Mfg., (800) 328-1752. www.tractorseats.com
Thu, Jan 21, 2010 12:41 PM
Reply to Mike Walsh:
You menioned Logging with that tractor on the other thread. Sounds like a work tractor that the seat is going to get wet, poked and worked hard. My recommendation is to buy something that is affordable and comfortable for you and don't worry if its not original. Besides if it gets vandalized out on a site at least you won't be out the price of a Hann seat.
Thu, Jan 21, 2010 7:06 PM
ol Grump
Reply to drujinin:
I've had several seats rebuilt by a local upholstery shop, cost is around $130 for both seat and seat back. The nice thing is that I can specify the foam he uses, one that's soft enough to pad my skinny old carcass well enough that I don't feel like I've been beat up after a day. The same thing goes for the side cushions, a fairly soft thicker than usual foam. Keeps from beating up my old hip bones ๐Ÿ˜†
I like to keep the old critter looking stock but then I like my comfort too.
Thu, Jan 21, 2010 10:17 PM
Rd6 plower
Reply to ol Grump:
Arm rest are a must if you're working the slopes!๐Ÿ˜„
Thu, Jan 21, 2010 10:56 PM
hahnseats
Send a private message to hahnseats
Thanks for all the recomendations. I try> I realize my seats are more costly. I just completed a cost analysis on all my products. cost of shop, heat, taxes, and supplies. UPS and USPO Supplies and shipping have doubled in the last few years. I cannot complete with local shop, when you supply the plywood and other goodies. I have spent many hours reserching, making patterns, fine tuning my product to fit your Cat, to put all the seams, T-nuts to fit seat bucket, the shape to match the orginal as much as I can. I will custom make your seat if you want something special. My Vinyl is the best I can buy. -40 degree cold crack, Its the same material I use on all the commercial contractors, Loggers, Mills, Farmers that I supply seats for. It will out last the orginal over and over. This is more of a hobby than a money maker. because I love these old tractors, Have operated many of them and enjoy the contact with the fellow collectors. I am willing to work with anyone to make sure you have what you need. Thank you again for yoiur friendship, phone calls and letters and pictures, Stop by if your in Idaho, Have a cup of coffee, I may even take you on a Caterpillar tour. Go look at some old Iron, a bone yard or two. John Hahn
Fri, Jan 29, 2010 2:40 AM
jfirebaugh
Send a private message to jfirebaugh
Barely Smokin',
I will also chime-in that John Hann seats are the best quality and fit that you can get! I was able to get my D46U seats from John at the Best Show on Tracks in Woodland, CA in 2008. John brought a pick-up load of seats with him for his booth. Getting them direct saved me the shipping! ๐Ÿ˜„
Best of luck with whatever you decide to do!
John
Sat, Jan 30, 2010 6:05 AM
| 1234 Carngham - Lake Goldsmith Road โ€‹Lake Goldsmith VIC 3373
| โ€œDe Domelaarโ€ Gebr .V.d. Heiden Domelaarsweg 3 7475 MARKELO Netherlands
