How do u protect open injector lines/
Knucklebuster
Send a private message to Knucklebuster
Hey Fellas
When working on injector lines such as pulling the head, how do you protect the lines and connections from dirt and contamination?
I just been using plastic and ties, I figure there are better ways if you don't have the Cat caps.
thanks
David
Wed, Oct 31, 2007 10:51 AM
John in Wy
Send a private message to John in Wy
Your way sounds good too. As well as tape the ends closed. John
Wed, Oct 31, 2007 10:56 AM
OlCatBob
Send a private message to OlCatBob
Reply to John in Wy:
I have used the rubber caps that come from an acetylene torch. I went by the local dealer just before last X-mas and he gave me a set of 4.
Bob
Wed, Oct 31, 2007 8:14 PM
SJ
Send a private message to SJ
Reply to OlCatBob:
Bob
Years ago Cat had aluminun threaded caps to put on the pumps & nozzle & later years they came with plastic caps on them. Any way to cover them is good so no dirt gets in them.I always had a bunch of the threaded caps so was no trouble around the shop.The real early caps I saw too were brass nuts (caps).
Wed, Oct 31, 2007 9:24 PM
Painter
Send a private message to Painter
Reply to SJ:
Small balloons work great, and are cheap!!
Hi, My name is Dennis, and I am a Rust-a-holic!
D4 7U17091 D6 8U10305 1926 Cat 30 1955 Ford T800, 74 Ford LT9000 1936 K Allis
Wed, Oct 31, 2007 9:40 PM
Thank you received: 62
Reply to Painter:
Just touched on that topic a couple days ago😊
http://www.acmoc.org/ACMOC_BB/showthread.php?t=2062
Wed, Oct 31, 2007 10:02 PM
