How di I start a Pony motor on a Cat D6?
Showing 1 to 10 of 18 results
runar500
Send a private message to runar500
A friend has been promised a Cat D6 for free, if we can start the thing. Let me assure you I am not going to give up easily! 👍
Although the Cat seems to have been well looked after, and stored under tarpaulins, we were not able to start the Pony engine first time we tried.
First of all, the sparkplug cords were pulled from the magneto when we got there, I need to know which cable goes where..
Secondly I think the carb needs a thorough cleaning, I will look into that next time, but was hoping someone might have some tips on the "does and don'ts" of this field?
And lastly, I don't think the compression is "all that". I noticed there is a tap on each sylinder, even if I close these, I suspect air is leaking from the taps.
I'd like to hear form anyone with experience on D6 starting procedures, and from any one who have info on the Pony engines!
Thanks!
Tue, Aug 21, 2012 9:02 PM
Normally you would told to do a "SEARCH" function first as this is discussed at least once a week, BUT this time I would recommend just reading back through the previous 5 pages of posts as there is a ton of information on the issues of magneto and carb problems on the D2 and D4 engines which share the same parts with the D6 you are having issues on.
Wed, Aug 22, 2012 12:48 AM
Moulding
Reply to drujinin:
You my try to pull the cat to get it started and work on the pony engine when you get it home .
Wed, Aug 22, 2012 1:37 AM
WyoCat
Reply to Moulding:
I agree with Moulding! Getting it home gives you the abilty to get everything in good order for the pony to run with out any time constraints or dragging tools to and from the place where it currently sits.
Chad Enyeart
Wed, Aug 22, 2012 2:16 AM
64farmboy
Reply to WyoCat:
Not saying it will happen here but I've had several instances once I got the free item working on site it was no longer free and not for sale
Wed, Aug 22, 2012 4:38 AM
runar500
Reply to 64farmboy:
Yeah.. That is actually something I guess we better prepare for mentally.. 😞
Wed, Aug 22, 2012 12:54 PM
runar500
Reply to Moulding:
I am not sure I understand.. "Pull the Cat to get it started"?
Please explain? :ear:
Wed, Aug 22, 2012 12:59 PM
D6 Pete
Reply to runar500:
Opps ,,, wrong editing ,,
Wed, Aug 22, 2012 1:00 PM
D6 Pete
Reply to runar500:
Get your self a operators manual ,, there are plenty on E bay ,, they are a must ,, you can get all the info for starting a D6 there ,, good luck .... also you need the serial # to get right book !! pete
Wed, Aug 22, 2012 1:02 PM
runar500
Reply to drujinin:
I also want info on HOW to start the Cat, if / when we get the Pony running. There are levers for starterclutch, for decompression, for trottle and one I don't know what is for, this is what I am trying to find out, as well as the "mecanical issues" of the Pony..
7upuller
Reply to runar500:
Hey Runar500,
Where is the Cat located? Maybe you should ask if somebody lives close by. There are a lot of tricks to these old Cats. We could probally walk you through it, but if you are not familiar with them, someone could get hurt. If you are not sure of what lever does what, when starting, problems can occur. If you are local, maybe someone could come by and give you a hand and a safety walk through.-glen
Wed, Aug 22, 2012 1:32 PM
