How bad is this crack?
Showing 1 to 10 of 29 results
hdroadkingc
Send a private message to hdroadkingc
I have a cat 951C with a bad final drive and pinion. Now that I have it apart, I found a hair line crack in the steering clutch housing where the final drive bolts too. The crack is on the upper part of the housing between the top and next to the top bolts for the final drive if that makes sense. It runs from a oiler hole, accross the mounting surface and about 5-6 inches back twards th middle of the machine. Should I be concerned about this or just get it welded up and put back together? I will try and get pictures tomorrow. I think the crack will be hard to see in pictures! Thanks for any help.
Sat, Dec 18, 2010 10:45 AM
Thank you received: 106
Hi, Hdroadkingc.
If you take a fine point felt tip marking pen, about an 0.4, which you might use for normal writing and use it to mark the line of the crack before you photograph it, it will give the folks on here a better idea of exactly where the crack is and how serious it might be.
As a 'general' rule, provided that such cracks are properly 'V'-ed out and welded by someone who knows what they are doing, they are seldom a problem. There can always be an exception to such general rule.
Hope this helps.
Sat, Dec 18, 2010 1:44 PM
Thank you received: 46
Hi, Hdroadkingc.
Hope this helps.
I hear about that happening ocassionally.....probably due to chunks between the gears during failure. Also can be caused by cocking of the the bull gear if bearing adjustment is not maintained. Don't hear to much about fixes and how they work out. The bad ones are major and turn in to parts tractors. Certainly worth a shot at welding it up. Can be a problem if the crack enters a bearing retaining bore.
Sat, Dec 18, 2010 1:58 PM
hdroadkingc
Here are the pictures of the damage. I hope this can be welded! Tell me what you think.
Sat, Dec 18, 2010 11:19 PM
Reply to hdroadkingc:
Yes, it can be welded but it will also require machine work to recover the bearing race fit....as indicated by the broken outer bearing race support and chip out of the outer race.
I don't see any broken teeth on the pinion, at least not on the side shown nor signs of gear tooth pieces going through and the wear pattern is fairly even so cocking does not appear to be the problem. May be a case of straight wear and some abuse.
Sat, Dec 18, 2010 11:58 PM
cr
Send a private message to cr
Thank you received: 29
The D5's and D6's track tractors of that vintage are known for cracking along the front of the case of the steering clutch housing. That picture looks quite bad. At the very least after that is welded the bearing bores will need to be line bored and sealing surface will need some work. That final pinion is about 400% worn looks like a deferred maintaince issue.
Here is a picture of a D5b that was brought in for its annual inspection, ended up getting new UC, finals and replaced 2 & 3 gears in the trans along with all of the bearings.
Sun, Dec 19, 2010 12:11 AM
ronm
Reply to cr:
Many years ago, when I was at the JD dealer, one of the salesmen traded for a nice D4 that had a crack all the way across the top of the case into the steering clutch compartment, it had broken a tooth off the bull gear...he tore it down himself, had too much in it to have the shop do it, & it sat outside the shop for about 6-8 mo., as I remember... a long time, anyway...finally got a local welder that could stitch anything back together to come & fix it. Turned out really nice, but the memorable part of the story is that he put the bevel gear in backwards, I will never forget the look on his face when he got her fired up, put her in 1st, & she went backwards...put her in reverse, & she went forwards...😆 He was not a happy camper to have to go back in & flop the bevel gear...Like the others said, that ugly bearing bore would worry me more than the crack, actually.
Sun, Dec 19, 2010 6:54 AM
AJ.
Send a private message to AJ.
Reply to ronm:
First you should get the steering clutches out,clutch drive flange off,the pinion and the pinion bearing carrier out,the outer end of the carrier is broken so you need a replacement,bolt it in place and see how it fits in the casing bore where it is cracked,it just slips in when good,it should be snug but as there is a bearing supporting the outer end of the pinion in the cover so you may get away with it,if its a little loose bearing lock or the like can be used,I'v even used a speedi sleeve,about the crack,if its not going to leak oil leave it,welding it will not stop it from cracking or the cracks getting longer,it is very crappy cast,metal stiching would be better,make sure the cover is not cracked as that will have to hold things together from now on.
AJ
Sun, Dec 19, 2010 8:54 AM
Reply to AJ.:
AJ
Hi AJ,
Ya got me breaking out the parts book...and yes it's the end of the cage that is broken. Also see this is still the same old housing arrangement (and problem) since the D4C. I'm not convinced that the failure would not occur again if the crack is not tended to. The cage still needs the support. Would agree the metal stiching would be a good alternative.
Sun, Dec 19, 2010 11:13 AM
hdroadkingc
Hi AJ,
The pinion bearing carrier is not broken. The crack starts in the oiler (I think)hole beside the pinion carrier. I am working on getting the pinion out now. Will let you knwo more when I get it out. Thanks.
Tue, Dec 21, 2010 1:18 AM
Hard to tell from the picture, what looks like a break may be just a step in the casting. If that's the case that's probably not enough crack to worry about.
Still need a good fit for the bearing race though. Check it out.
From another view (D4 in this case) same drill:
Tue, Dec 21, 2010 2:16 AM
