Hose -Replacement
Hose -Replacement
Tim Matthews
Send a private message to Tim Matthews
D-6 8-u ; While I have the radiator out my hydraulic cylinder hoses are easy access. Could anyone tell me what size to ask for?
I know I could take it off and check but I would like to have part in hand. Thanks Tim
Sat, Aug 24, 2013 11:14 PM
Thank you received: 62
If it is the original Cat fittings should be 1 inch hose. With the bolt on clamps you don't have to buy any fittings.
Ray
Sun, Aug 25, 2013 6:39 AM
chumduffy
Send a private message to chumduffy
Reply to Ray54:
Ray
Hello Tim; doing all four lines on our 9U this week end. They are one inch, we've had bad luck with our belly pan bolts twisted off three hope your having better luck. Chum
Sun, Aug 25, 2013 1:50 PM
Tim Matthews
Reply to chumduffy:
I have been asked for a specification. Isnt it single braid 2000lb I dont know? Thanks again Tim
Sun, Aug 25, 2013 8:47 PM
Reply to Tim Matthews:
I have not been able to find the original specs.
Per my 1970 "One Safe Source" catalog Cat uses their own spec for hydraulic hose, minimum 4,000 psi, 4-spiral wire wrap but they are more interested in flexibility and pulse cycles.
In terms of pressure (1200psi max) on the #46 HCU a two wire SAE100R2AT (2 wire) would probably work fine but the catch might be the hose O.D. in order for the split clamps to hold.
http://parts.cat.com/cda/files/3068179/7/PEHP9519-02.pdf
Mon, Aug 26, 2013 12:01 AM
chumduffy
We used Weatherhead double braid hose it seems to fit fine on the inside and the out side of the old cat fittings
Tue, Aug 27, 2013 10:21 AM
