Hone for D2
Hone for D2
Showing 1 to 10 of 12 results
rockymnt
Send a private message to rockymnt
Getting ready to put pistons back in and I would like to know what grit of a ball hone is best. Also, is the chassis manual the best to show what the rear sprockets are to be pushed on with ? I have a parts and engine manual.
Thanks for any help.
1952 Cat D2
Sat, Feb 25, 2017 4:56 AM
TOGNOT
Here is my opinion - I'm sure there are better ones -
The hone needed is the one that will give new rings a rough surface to seat on. For many years I have used a spring loaded 3 blade "stone" type hone on cylinders, automotive, motorcycles, hydraulic cylinders, etc.
This is all stuff in my home shop. All of it worked, rings always seat. They aren't too expensive and it has lasted years. It might sound strange, but with this type of hone I have used hot soapy water as lubricant. It keeps the stones from clogging up and cleans the cylinders. Keep the hone moving, don't stop once you start.....
Sat, Feb 25, 2017 11:14 PM
https://www.hastingsmfg.com/ServiceTips/cylinder_bore_refinishing.htm
This is just one of the entries i found by a google search for what grit for cylinder hone. Take your pick!
In my past endeavors, I have had trouble getting a "steep" enough crosshatch. This mainly results from the minimum speed of the electric drills I have been using to spin the hone being higher than my ability to repeatably move the hone up and down in the cylinder without going too far and the 3 wing flex hone stones popping out and getting chipped.
Sun, Feb 26, 2017 1:38 AM
Thank you received: 77
I've used ball hones successfully on small block 350s in the past
Sun, Feb 26, 2017 5:11 AM
Big difference in honing cast iron vs hardened liners.
Sun, Feb 26, 2017 5:20 AM
I've used a Ball Hone just to scuff up a D2 liner. Its been so long ago I seem to remember it being somewhat successful? Rings seated, so it must have worked....
Sun, Feb 26, 2017 9:17 AM
rockymnt
Reply to drujinin:
I did a little looking on the web also, and if you follow this link, http://www.enginehones.com/technical.html it gives a quick tutorial. SOooo what is recommended, a ball or a stone hone for a D2 with a shiny glaze on the cylinders?
And thank each of you for your input !!!!
1952 Cat D2
Sun, Feb 26, 2017 9:47 AM
rmyram
if all your doing is trying to get rid of the glaze, the ball hone will work fine. you do need to make sure you move it in and out at the proper frequency compared to the speed of the drill to get the correct crosshatch angle.
Sun, Feb 26, 2017 9:52 AM
Reply to rmyram:
Should use one with Aluminum Oxide stones, maybe 180 grit or what others recommend.
Sun, Feb 26, 2017 12:55 PM
Post #6 has a photo of a homemade Sprocket Press!
http://www.acmoc.org/bb/showthread.php?19334-D2-4U-putting-back-together
Without going back through the Files, I believe CAT recommended 15 tons but it has been down graded to 10 tons? There is a Spec sheet on a Thread around here somewhere!
Sun, Feb 26, 2017 8:13 PM
8C 361
Thank you received: 12
What about acid etching or are aftermarket liners not hardened?
Sun, Feb 26, 2017 8:52 PM
