Homemade electric conversion
49D73T
Send a private message to 49D73T
Delco 35mt CCW starter from an IH 1486 adapted to pony clutch bell housing. Clutch shaft 6spline fitted with gear from a ford tractor hyd pump drive that has the correct pitch to match stater pinion and 6 spline center bore. Works decent think i need more amps though[attachment=38329]image.jpg[/attachment][attachment=38330]image.jpg[/attachment][attachment=38331]image.jpg[/attachment][attachment=38332]image.jpg[/attachment]
Sat, Oct 15, 2016 5:16 AM
Thank you received: 46
A 35MT doesn't have enough a$$ to do the job.
Sat, Oct 15, 2016 7:19 AM
mrsmackpaul
looks good to me as long as it works is all that really matters and it isnt a pilot motor so its gunna be a lot easier to start
May need a tad heavier wires but I feel your onto that
Paul
Sat, Oct 15, 2016 7:21 AM
49D73T
Reply to mrsmackpaul:
Paul
Well its doing it. Compression lever to start, spin it for 10 sec then throw to run and it starts. Should mention the gear on the spline clutch shaft is 37 teeth vs the starters 10 so its geared a little. Using 2 ga. solid copper
Sat, Oct 15, 2016 12:04 PM
mrsmackpaul
Reply to 49D73T:
only thing to think about if its winding over with no compression it wont build heat from compression and may make it harder to start on a cold morning
And if it miss fires it can break the pinion or so I have been told
Old Magnet will know better than me but I understand that it should be wound over under full compression for a few seconds then open up the fuel and they start instantly
If you start winding over with the throttle open they can miss fire and thats when a pinion can break
Paul
Sat, Oct 15, 2016 2:26 PM
49D73T
Paul
True on pinion. Will have to watch my start procedure. I must say when lever is on start it still has a decent compression cycle. Almost like two of the valve lifters are adjusted to not engage.
Sat, Oct 15, 2016 7:37 PM
