Home made shearing blade
Showing 1 to 10 of 20 results
Pioneernorth
Send a private message to Pioneernorth
So I'm really wishing I had a KG blade and have been outbid at the latest Ritchie sales. I'm onto one in Edmonton right now but after auction fees and trucking it will be close to 10 grand to get it to me. Would fit my 8H. Here are the questions: Is it really night and day for clearing(mainly frozen ground) with a kg versus the regular angle dozer? And I have an old blade laying in the bush that is wore right out. The skin is wore through and pushed back. Thinking about welding a plate along the bottom and redoing the curl with some big pipe or even an old propane vessel. I do have a road packer drum that is AR type steel but don't think it needs it for mainly trees and the limited use I will use it for. Give me your thoughts and thanks in advance. I know kg blades are more common in the south than northern Canada. Could use a big one for the 8H or a 7 size for the 14a.
Thu, Dec 13, 2018 10:26 AM
janmeermans
Rome KG,
Here is your chance Rome. Help out "Pioneernorth" and coach him on how to convert that old blade into one of your slick stump disintegrators! Surely you have tackled a few well frozen in stumps back there in Ohio!
JanM
Thu, Dec 13, 2018 10:47 AM
Reply to janmeermans:
Rome KG,
JanM
Ok Ok calm down!, lol The blade would have to have a flat cutting edge, with the ground, at least 1 1/2" thick and the point on the left hand side should be at least 2" thick with a long tapered point about 8-10". The only thing is the push braces are very light for a clearing blade on the angle blades.
Thu, Dec 13, 2018 9:31 PM
Pioneernorth
Great pics Rome KG. I have never seen an actual kg blade in real life. They are rare in these parts. Question is am I actually gaining enough to make it worth all that work and/or money. Looking for some responses on actually using these things. I don't need it for chiselling down huge trees. Mainly for cutting off 4 to 5 inch spruce. I see the Weldco version at Ritchies is up to 8250 before auction fees this morning. Add a couple grand for trucking and I can damn near buy another cat for that much! Is the job it does that much different than just the angle blade?
Thu, Dec 13, 2018 10:07 PM
D2 Cody
Send a private message to D2 Cody
Reply to Pioneernorth:
Pioneernorth,
Check out a website called the perfect tree saw, i tried to buy a used one for my 6C a year ago but lost the bid. I have a buddy that has the smaller version on a Deere compact track loader and likes it. I have never run one myself but they look pretty heavy built and priced right. Hope this may help. Cody.
Cat D6C 76A2045
Cat No. 12 8T15616
Cat D2 5U15751
Fri, Dec 14, 2018 3:03 AM
bursitis
Reply to D2 Cody:
Pioneernorth,
i second the perfect tree saw. they are awesome especially if you don't mind leaving the stump.
Fri, Dec 14, 2018 3:25 AM
Reply to bursitis:
Those tree saws are ok for little stuff, When you get into hard trees and tangled brush and have to get the roots out, nothing beats a K/G blade, I have used Rome blades for 30 years and my dad for 45. Great for ditch bank clearing and getting stumps split up small and the dirt breaks off the roots so they burn up fast. Only disadvantage is rocky soil, dents the sharp edge. Yes the shearing edge is much better the blunt angle blade edge.
https://youtu.be/04Kxk0DZdYI
https://youtu.be/2CKSwImh7TY
Fri, Dec 14, 2018 4:46 AM
I think if you refab the angle blade with the flat shear edge it may work for you. Keep searching the net, Machinery Trader, Iron Planet, Rock and Dirt. Try Crawford Jarvis in Georgia, he may have something, 770 748-8000
Fri, Dec 14, 2018 4:53 AM
Pioneernorth
Reply to bursitis:
Thanks guys. Is there anyone who has actually cleared a few hundred acres on here with a KG blade? Put the cat in second gear and windrow the scrub timber over. I've got a feller buncher and grapple skidder(both Cat) for any serious logging. I want to know if the Kg is so much more efficient that it's worth the added investment versus the regular angle dozer with a good cutting edge. Must be some pioneer's in the group here. Nice to get some input from those that have some serious hours behind a KG. Will the KG make the Cat that much more efficient?
Fri, Dec 14, 2018 4:56 AM
This is the tree trunk from that six foot across stump, weighed 32,000 lbs, 35' long. 2nd pick is of me my grandson and son, fourth pic is my daughter and I taken 2015 and my sister and dad taken around 1968. Saw is a Stihl 090 with 59" bar.
Fri, Dec 14, 2018 5:09 AM
These are some big Oak stumps that a goof ball dug out with a D9H and a "u" blade, I had to come in and clean up and finish the job after his mess, limbs and brush laying everywhere and half buried. Couldnt burn these big dirt balls, had to push them into the woods to rot. He had dumped so much fuel on the stuff to try and burn it that it turned the dirt all orange! I had to tear the piles all apart clean them out and restack them. What a mess! Some clowns just dont understand that dirt wont burn. lol
Fri, Dec 14, 2018 6:12 AM
| Kingaroy, Queensland
