Holt-Midwest engine
Holt-Midwest engine
EL300B
Send a private message to EL300B
I have a Holt 4 cyl. engine made by the Midwest Engine Company.Side covers say Holt and the exhaust manifold has the wavy caterpillar script.Piston bore appears to be 6 5/8 inch.There is a plate on it that has Holt 55-75 HP engine Built by Midwest engine Co. successors to Lyons-Atlas Co.Indianapolis Indiana.I was able to find out Midwest engine was formed in 1918 and went bankrupt in 1922.Is this the same engine as used in the 10 ton?Was it common for Holt to contract with other companies to make engines?I'm missing one head and now the exhaust manifold has disappeared.I asked on here once before but found little information I'm hoping to find out more this time. Thanks
Sat, Jun 29, 2019 9:18 AM
Bruce P
Thank you received: 40
Could be similar to a ten ton. How many flywheels? What sort of clutch if it has one? Could be a combine engine. The self propelled combines used a 55 horse engine and had two flywheels. I’ve got a few 45 horse heads, not sure if they’d interchange. Now go find that manifold!!
Also pictures would be cool too.
BP.
Sat, Jun 29, 2019 9:51 AM
EL300B
Reply to Bruce P:
BP.
I think I found what I was looking for,went to the archives and found a post by dtallon where he said there was a block of serial numbers assigned to T-16 (10 ton) tractors with Midwest engines.Engine has one flywheel with teeth for a starter(I presume) and a belt pulley operated through an over center clutch.As far as the manifold goes I have a family member who thinks anything not nailed down or locked up is fair game,or at least that is my suspicion.I tried to take pictures but my camera is junk and I need a new one.Have had the engine 40 years and figured I could work on it after I retired,but will probably have to work until I can't.It will probably be for sale.Be interesting if one of the 45 heads would fit.Engine was being used on a sawmill when I got it.
Sun, Jun 30, 2019 7:46 AM
WyoCat
Reply to EL300B:
45 heads and 10 ton heads are close, but not identical. PM me if you need any 10 ton parts to complete it.
Chad Enyeart
Mon, Jul 1, 2019 8:20 AM
EL300B
Reply to WyoCat:
Thanks,haven't made up my mind yet ,will PM you when I do.Right now am missing one head with rocker arms and valves,and possibly exhaust manifold.Are these parts available?
Mon, Jul 1, 2019 11:49 AM
