Holt blade restoration on D2 5U
Showing 1 to 10 of 37 results
case on a cat
Send a private message to case on a cat
[attachment=39481]image.jpg[/attachment]
So, here is my D2 in all its glory shortly after procuring it.
I put a few hours of much needed work in around our property. When I posted earlier, a member pointed out how warn the blade is. I had no idea what I was in for then.
Now after months of working on it here and there, I am starting to see a little light at the end of the tunnel. Here are a few pics of my progress so far. I'm almost done with the back side, then it's back to filling and grinding flat the last of the front. Before the blade goes back on I am going to do a little maintainance to the #44 pump unit and install a pump guard I scored from D4e.
I can hardly contain my excitement.
[attachment=39482]image.jpg[/attachment][attachment=39483]image.jpg[/attachment][attachment=39484]image.jpg[/attachment][attachment=39485]image.jpg[/attachment][attachment=39486]image.jpg[/attachment][attachment=39490]image.jpg[/attachment][attachment=39487]image.jpeg[/attachment][attachment=39488]image.jpg[/attachment][attachment=39489]image.jpg[/attachment]
Sun, Dec 25, 2016 10:09 PM
STEPHEN
Hey Case, looking good I'm excited too. What are you doing about new cutting edges?
Sun, Dec 25, 2016 10:55 PM
case on a cat
Reply to STEPHEN:
I found a local shop that was able to make the end pieces from scratch and shorten a larger blade with correct holes to make the center section. I got the three pieces and hardware for about $400. The new cutting edges are 5/8's thick instead of the original 1/2". The angles are a little different too. I will try to shape the molding board to correspond with the new cutting edge cross section. Fortunately that is the one area I still need to finish on the front of the molding board. I thought I took pictures of everything, but I guess not. I will get some pics later today.
The experience was excellent at the shop I went too. I was worried that my project would be to small for them, but I felt like they valued my business as much as a large/regular customer.
http://www.cuttingedgesupply.com/
Sun, Dec 25, 2016 11:29 PM
mrsmackpaul
Reply to case on a cat:
Looks really good to me and there is a lot of work goes into repair a blade or even a ripper tyne when it gets worn down like yours was
Paul
Mon, Dec 26, 2016 2:14 AM
Kenny Walker
Send a private message to Kenny Walker
Reply to mrsmackpaul:
Paul
Looks realy nice! Cant wait to see the end product.
Mon, Dec 26, 2016 3:08 AM
Paso Bob
Reply to Kenny Walker:
Nice looking work.
Mon, Dec 26, 2016 12:02 PM
Thank you received: 140
Reply to Paso Bob:
Nice looking work.
Hi, Case on a Cat.
That is starting to look almost like it was done by somebody who knew something about it. LOL. Great stuff. M8. Thanks for sharing.
Mon, Dec 26, 2016 12:18 PM
janmeermans
Hi, Case on a Cat.
Carl,
You are doing a bit of nice work there. I am jealous of your shop and set up. Is there any room for my 14A up there? Very convenient that Cutting Edge Supply is close by.
Are you thinking of bringing your D2 up to SM for the show? The Chapter has some options to get it up there and back without breaking the bank. Stay in touch as the time gets closer.
JanM
Mon, Dec 26, 2016 10:24 PM
case on a cat
Reply to janmeermans:
Carl,
JanM
Ah shucks guys. Thanks for the complements. I am gonna try and get some hours in this week. This project is pretty different from the usual fabrication that I've done for work or myself. I just keep asking myself what would my Isntructors and mentors do about this? Then take a minute and critique my progress top to bottom.
My wife was a little upset when I told her we should take the cat apart shortly after buying it. I can see her point of view, but I reminded her that this thing is 70 years old. Part of her concern was maintaining a value, both dollar wise and in terms of its usefulness. I showed her pictures of molding boards with a patch work of rusty plates. I pointed out that we purchased the tractor so cheap, and my work will likely turn out good enough to be valued higher than wwe paid for the whole thing considering an hourly shop rate.
I work for my uncle as a machinist and fabricator. He put it best, when I got started. "Better weld that up while there is still something left to weld to."
Here's a pic of the cutting edges as promised.
[attachment=39497]image.jpg[/attachment]
Deas, brace your self for a flood of questions once this thing is back together. Ha
Jan, I actually would have space. I built a beautiful 2" receiver hitch on a 1986 military 5 ton 6X6 for a close friend. I'll dig up pics of the rig inside my shop. That was a fun project. It really helps have such a good space to work in with good tools. I am very gratefull for that.
I am really hoping to get to the SM show with my D2. It will have to get picked up at my place. I don't have a safe way to move the D2... Yet
Mon, Dec 26, 2016 11:48 PM
case on a cat
I finished the last of the fab work I wanted to do on the back side today
[attachment=39503]image.jpg[/attachment]
A previous owner added these 4 brackets to the back side. I'm assuming it was for some kind of screen. I'd like to take them off and clean the molding board up. Could the brackets be for something else? Should I keep the brackets?
[attachment=39504]image.jpg[/attachment]
Tue, Dec 27, 2016 11:10 AM
Hi, Case on a Cat.
Lookin' good.
Those brackets look to me as if they might have been for a hungry board or some sort of protection for the radiator when clearing. If you don't have the bit(s) that bolted on there, I don't see much point in keeping the brackets unless you would like to make up something similar yourself somewhere down the track. The only real uses for such a board would be when clearing or when pushing really light material such as wood chips. With the width of the 5U blade, the tractor will have pretty much all it can handle with a full blade of dirt as is, although an angle blade doesn't 'fill up' like a straight blade 'cos it is designed to roll the material on the blade.
If I was much good at worrying, this line from your last post might have me worried, and I quote:
"Deas, brace your self for a flood of questions once this thing is back together. Ha"
Unquote.
I would like to know though just why you are pickin' on ME? WHAT have I ever done to you? LOL.
Tue, Dec 27, 2016 12:07 PM
