Holt 45 hp engine
Holt 45 hp engine
Showing 1 to 7 of 7 results
Jim Gorter
Send a private message to Jim Gorter
Good Friday to all. I have posted some pictures of the Holt engine on my Flickr page. Go to http://www.flickr.com/photos/rusty_acres/
After a long search for machine shops to hone my cylinders, I bought a hone on ebay and did it my self. The cylinders came out nice. valves/seats have been ground and hand lapped.New rings have been fitted to the pistons and wrist pins have been readjusted. Even made some progress on the steel wheeled trailer it will be mounted upon.
I know this is not Cat Crawler related ,but since Holt was the parent company to Caterpillar, I thought some would like to see it. Thanks, Jim.
Sat, May 3, 2008 4:33 AM
WyoCat
Jim, Thanks for sharing. Sure looks like it will make a nice display when you are done.
Chad Enyeart
Sat, May 3, 2008 5:00 AM
daron
Reply to WyoCat:
Did you use the punch to clean the rust or to free up a stuck piston?
Thanks, Daron
Sat, May 3, 2008 11:26 AM
Jim Gorter
Reply to daron:
Thanks, Daron
Daron, I use the "punch" to free up stuck pistons and valves. BTW, it is not Hawaiian Punch, but a 50/50 mix of diesel and ATF. Works great on loosening up engines which had gotten water down the exhaust stacks. JIm.
Tue, May 6, 2008 1:56 AM
chriscokid
Reply to Jim Gorter:
jim,
what is ATF, that you used in the 50/50 mix?
Tue, May 6, 2008 4:02 AM
Jim Gorter
Reply to chriscokid:
jim,
Chriscokid, ATF is Automatic Tramsmission Fluid. Its is a great penetrant and does not evavorate. It also has additives to clean varnish and crud in tight places. It works great in freeing stuck cylinders. Jim.
Tue, May 6, 2008 5:44 AM
Toolbox
Send a private message to Toolbox
The last one I freed up was combination of ATF and Marvel Mystery Oil because I ran out of Marvel. Might not work again but it did on that one.
Thu, May 8, 2008 10:40 AM
Reply to Toolbox:
A 50/50 mix of Acetone and ATF makes a fine penetrant also.
Thu, May 8, 2008 11:36 AM
