Holt 45 engine parts needed
anr.red
Send a private message to anr.red
Can anyone direct me to some repair parts . Need gaskets,1 push rod,1 rocker,oil pump,radiator vertical tubes.Dick,. 989-561-5888, Mi
Wed, Sep 25, 2019 2:32 AM
Bruce P
Thank you received: 40
Welcome, I went through a 45 last year. I know I’ve got a push rod. I might have a rocker arm. I got head gaskets from Olson’s, intake and exhaust gaskets are really close to the copper seal ring used on Caterpillar oil drain plugs and fill plugs. (3T D7 final drive fill for example). For the upper water manifold gaskets, I used the rubber gaskets from a small banjo camlock fitting. The rest of the gaskets I made.
I’ll give you a call tomorrow.
Bruce P.
Wed, Sep 25, 2019 9:35 AM
