Hi need help d4 7j starter bendix removal procedure
Steven
Send a private message to Steven
Hi need help d4 7j starter bendix removal procedure . does governor have to come off? fuel pump need to come off?
thanks for the help
Steven
Wed, Jul 29, 2015 3:18 AM
gemdozer
Thank you received: 12
For removed the cluch and starter pinion you do't need to removed the fuel pump and governor but need to raise the poney motor 2 inchs to clear the gear
Wed, Jul 29, 2015 5:30 AM
Mike Meyer
Reply to gemdozer:
Hector is right as usual, I believe it also helps to engage the pinion latches too so the over all length of the starter pinion is shortened enough to help it slip out past the governor, those pinions are a snug fit so use plenty of lube beforehand as you might find rust or the old seal will try and hold it tight, be patient and go easy with the big hammer.
Mike
Wed, Jul 29, 2015 7:16 AM
