Hex Key for D4 drain plugs
Showing 1 to 10 of 18 results
Cat99
Send a private message to Cat99
I need help finding the right hex bit for the drain plugs on a D47U. I have been using a plumbers shower drain socket but they are kind of flimsy. I went to Caterpillar but they list a 15/16" and 1 1/8" hex key for the D4. Does anyone know which is the correct size or are both sizes needed? They don't sell the original tool that came with the tractor anymore.
Thank You
Fri, Apr 15, 2011 10:17 AM
KCB
Send a private message to KCB
The drain plugs on the D4 are 1 1/8". You can make a tool from a 3/4" bolt with 1 1/8" hex head. Or buy this CAT tool, 5S9569 - it has both 15/16" and 1 1/8" for use with 1/2" drive.
[attachment=8625]5S9569.jpg[/attachment]
Fri, Apr 15, 2011 10:56 AM
Steve A
Reply to KCB:
Kent
I have never seen one of those--thanks for posting๐Ÿ‘
Fri, Apr 15, 2011 11:09 AM
Thank you received: 98
Reply to Steve A:
Kent
Hi, Cat99.
As mentioned above, Cat does/did make a tool for this purpose. In fact, they made at least two versions that I am aware of, the 1/2" square drive version shown above and one that had both hex fittings on one end of a handle about 8" long that was robust enough to take a '2,000# tension wrench' - a 4-foot length of 1" - 2" pipe.
In my own humble estimation, 1/2" square drive equipment can be a bit 'iffy' with some of these plugs as they seem to have a habit of tightening themselves up over time.
You can also make your own, again as mentioned above. When I have made them in the past, I have welded a 2"-long bolt of the appropriate size to a 3/4" round bar handle about 12" long for some applications and simply welded a nut onto a bolt of the appropriate size for other situations where a bit of reach and a socket with extensions might be needed, such as a drain plug up inside a belly pan.
Also as mentioned above:
5/8" bolt usually equals 15/16" head - check it with a 15/16" SAE wrench to make sure that somebody has not landed you with a 'ring-in'.
3/4" bolt usually equals 1 1/8" head - again, check it.
Just one other thing - most of these plugs come complete with a copper washer as a seal. Make sure the copper washer IS there and in good condition before replacing the plug.
Hope this helps.
Fri, Apr 15, 2011 1:23 PM
Cat99
Hi, Cat99.
Hope this helps.
Thanks for all of the good information. I will check with CAT and see how much the tool is. The 1/2" inch drive doesn't sound stout enough but should work well with a reducer from a 3/4". If the price is too crazy I will use a bolt until I can find the right tool used somewhere. Thanks again for the help.
Sat, Apr 16, 2011 12:25 AM
D6c10K
Send a private message to D6c10K
Reply to Cat99:
Cat shows old p/n 5S9569 changed to 212-8146..... available for $44.08
Sat, Apr 16, 2011 1:27 AM
Thank you received: 27
Reply to D6c10K:
for really tight plugs use a 3/4" drive socket and bar on the outer hex of the 1/2" drive type wrench, also for the older handle style wrench as well, for ease of removal. As suggested you will shear of the 1/2" drive on your favourite bar and cause lots of bad language to happen !!!!
At The Dealer I used to give the flange of the plug a couple of moderate of hits with a hammer to ease the grip of the gasket to ease removal, also did this on tapered plugs where fitted on later machines.
Also be aware that if you tighten a cold plug into a hot housing the plug will expand and be almost impossible to remove. I used to install the plug loosely and wait a minute for it to expand and then tighten moderately, this is vital on tapered thread plugs, they could split a housing.
Sat, Apr 16, 2011 8:11 AM
Julian
Send a private message to Julian
Reply to edb:
I just dug out an old imperial nut and bolt from my spares pile and welded the nut to the bolt. I used a big old ring spanner on the thing. (and a length of pipe for more leverage if needed)
Not all nice and shiny like a proper tool but it worked fine and cost about 1/4 of a welding stick!
Julian.
D47J5052
Sat, Apr 16, 2011 4:11 PM
terrywelch_archive
Reply to Julian:
Julian.
Kent, where did I see one of these?? Last weekend changing oil on some machines? Bill's homemade wrench worked well also.
Thanks for the help last weekend
Terry
Sat, Apr 16, 2011 5:52 PM
navistar275gm
Send a private message to navistar275gm
Reply to terrywelch_archive:
Terry
HERE I THOUGHT I WAS A " ECONOMICALLY EFFICIENT" TITEWAD, FORMALLY KNOWN AS A CHEAP TITEWAD. I DO LIKE THE WAY YA ALL THINK THOUGH. A GRADE 8 3/4 BOLT FROM THE BIN AND SOME HOT ELECTRIC GLUE DOES WONDERS BECAUSE THAT IS EXACTLY HOW I MADE ALL MINE...........๐Ÿ˜†
Sat, Apr 16, 2011 7:51 PM
B4D2
Reply to navistar275gm:
๐Ÿ˜† I like that.... ๐Ÿ‘
Sat, Apr 16, 2011 9:49 PM
| 1234 Carngham - Lake Goldsmith Road โ€‹Lake Goldsmith VIC 3373
| โ€œDe Domelaarโ€ Gebr .V.d. Heiden Domelaarsweg 3 7475 MARKELO Netherlands
