Help with serial # 9u
7mileranch
Send a private message to 7mileranch
Looking at a Agriculture D6 9U #20932 Transmission 3H2600
My 9U is # 22084
Will these cats work for parts and undercarriage
Sun, Mar 15, 2015 6:30 AM
3H2600 is an attachment option gearing where the normal gear group is 3H2616.
Other than a few different gears the tractors are pretty much the same and parts are interchangeable.
Where are you located? Just curious.
Sun, Mar 15, 2015 8:27 AM
7mileranch
[quote="Old Magnet"]3H2600 is an attachment option gearing where the normal gear group is 3H2616.
Where are you located? Just curious.[/quote]
Trail B.C. Do you know what the shift pattern would be
Sun, Mar 15, 2015 9:20 AM
Reply to 7mileranch:
I couldn't find anything that says the shift pattern would be any different. Just a couple of gear ratios are different.
Sun, Mar 15, 2015 9:39 AM
7mileranch
yes, seemed to move quicker
Sun, Mar 15, 2015 10:40 AM
