Hi, Xtremist.
If you can post some photos of what you have, I am pretty sure that somebody smarter than me will be able to identify your system. Not all Cat crawlers had Cat systems. There were a goodly number of after-market systems too.
Azfer your rapidly descending blade rams, that could be worn ram piston seals, wrongly set or failed relief valve or bypassing in the control valve, or any combination thereof, though it would HAFTA be a helluva bypass in the control valve to cause that quick a drop.
I'll let those with more knowledge than me step in here now.
whoops not sure why there are a bunch of sets of the same pictures.
[quote="Xtremist" post=228640"]whoops not sure why there are a bunch of sets of the same pictures.
[/quote]
I'm not sure eather but every time I add a pic then cut and past it doubles the pics ... It helps to add pics last
Hi Xtremist, Back in the day Caterpillar had a wierd system of having a seperate Parts Book for each attachment/system. I don't have the Parts Book for the basic No.46 hydraulic system but I do have the Parts Book for the 6A & 6S blades, oddly the hyd. cyl. parts are listed in that book. I have attached all three pages as I don' know your S/N.
Craig
[attachment=63357]IMG.jpg[/attachment] [attachment=63358]IMG_0001.jpg[/attachment] [attachment=63359]IMG_0002.jpg[/attachment]![]()
id love to track down a book as soon as i can figure out what it actually has for a system....is it a #46 ? the serial number on this machine is 9u2657 so its an earlier one....
I just edited the pictures in my last post and rotated them.
The parts book you need is the Caterpillar No. 46 Hydraulic Control Parts Book. These books are sometimes available on ebay, just keep looking.
Your rapid blade drop can be caused by several things but the most obvious is the failure of the lift cyl. lift rod seals causing a low oil situation. Prolonged operation with low oil will cause pump failure.
While you shop ebay also look for the Caterpillar Operation and Maintenance Instructions for your machine, it will save you time & money.
Craig
