Help with 955 12A1408 Clutch assembly
Showing 1 to 10 of 14 results
56Cat
Send a private message to 56Cat
I'm doing everything possible to removing my clutch shaft and assembly. The shaft will not clear the input shaft, I have the clutch engaged. Can someone call me and discuss this over the phone with me. Thanks, Russell 254-485-5214 I'm in Texas.
Mon, Apr 25, 2016 5:39 AM
56Cat
Or which D4 manual should I purchase?
Tue, Apr 26, 2016 7:09 AM
Thank you received: 50
Reply to 56Cat:
Procedure is well explained and straight forward as described in the (must have) Servicemen's Reference Book for the D4 Tractor.
Form # 30521-2.
Tue, Apr 26, 2016 7:22 AM
56Cat
Form # 30521-2.
Thanks Ole Magnet
Tue, Apr 26, 2016 7:40 AM
sdmuleman
Send a private message to sdmuleman
Reply to 56Cat:
Thanks Ole Magnet
OM, will a 60A 955 manual help him any? I have that and the 2T/5T/7J/5G D4 manual in my pdf library.
Tue, Apr 26, 2016 12:24 PM
catsilver
Reply to sdmuleman:
60A is powershift, totally different, use the book with 6U/7U details in it.
Tue, Apr 26, 2016 2:51 PM
sdmuleman
Reply to catsilver:
Got it. Of course 6U/7U is one that I don't have...
Tue, Apr 26, 2016 9:42 PM
catsilver
Reply to sdmuleman:
D4C 40A is pretty close as far as clutch removal is concerned.
Tue, Apr 26, 2016 11:22 PM
gemdozer
Reply to catsilver:
If I remember you need to removed the sleeve from the pinion starting engine to removed the cluch ass
Wed, Apr 27, 2016 12:10 AM
sdmuleman
Reply to catsilver:
Well I do have that one.
56Cat, PM me your email if you want it.
Wed, Apr 27, 2016 1:37 AM
56Cat
Reply to sdmuleman:
Thanks for all the help!
Wed, Apr 27, 2016 8:58 AM
