Help needed.please.......
chumduffy
Send a private message to chumduffy
Valve lash settings on A D8- 2U,22289.
Fri, May 24, 2019 5:57 AM
Never easy.....
For 900 RPM engines Hot at 0.012"
For 1200 RPM engines Hot at 0.016"
2U 7129-up has a full load rpm rating of 1000 RPM
The 13A is a 1200 RPM engine
Add 0.002" if set cold.
Fri, May 24, 2019 10:29 AM
chumduffy
Never easy.....
Thank you Old Magnetic. Seem to have a lisp that comes and goes?
Sun, May 26, 2019 2:57 AM
Thank you received: 77
Reply to chumduffy:
Hi chum, is the show the 8th and 9th of June this year?
Sun, May 26, 2019 7:07 AM
